Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Toyota 2007 and Newer Tundra Heavy Duty Differential Cover from Barnes 4wd!
Old Jul 7, 2016 | 04:03 PM
Barnes 4wd's Avatar
FormerVendor
Barnes 4WD is proud to introduce the first Toyota Diff Cover that offers complete protection for your third member, maximizes clearance and increases fluid capacity. This cover is not your typical cap that you just weld over the thin stock housing. With our cover you completely remove the factory cap (a quick job with a cut off wheel) and weld a laser cut and bent ¼" A50 Plate Steel cover in its place. This is a little more work but the payoff is worth it for the total coverage and increased oil capacity. Covers ship fully welded with a large fill plug so all you have to do is prep your axle and weld it on! This is also the most economical fix for a rusted leaking Toyota rear axle.
This cover will fit.
2007-2015 Tundra
2007-2011 Sequoia
Click Here To View Our Toyota 2007 and Newer Tundra Heavy Duty Differential Cover
Old Jul 14, 2016 | 09:25 AM
Barnes 4wd's Avatar
FormerVendor
The Tundra's need love too!
Old Jul 20, 2016 | 09:43 AM
Barnes 4wd's Avatar
FormerVendor
Back to the top!
Old Aug 5, 2016 | 05:59 AM
Barnes 4wd's Avatar
FormerVendor
It's trail time!
Old Aug 11, 2016 | 04:31 PM
Barnes 4wd's Avatar
FormerVendor
Thanks for another busy day!
Old Aug 19, 2016 | 12:32 PM
Barnes 4wd's Avatar
FormerVendor
We hope everyone has a great weekend!
Old Aug 24, 2016 | 01:09 PM
Barnes 4wd's Avatar
FormerVendor
This week is flying by! It's probably because we are so busy! Thanks everyone!
Old Aug 31, 2016 | 02:52 PM
Barnes 4wd's Avatar
FormerVendor
Midweek bump!
Old Sep 12, 2016 | 10:24 AM
Barnes 4wd's Avatar
FormerVendor
Hope you all had a great weekend!
Old Sep 20, 2016 | 03:52 PM
Barnes 4wd's Avatar
FormerVendor
It's upgrade time!
Old Sep 28, 2016 | 05:05 PM
Barnes 4wd's Avatar
FormerVendor
Midweek bump!
Old Oct 6, 2016 | 07:47 AM
Barnes 4wd's Avatar
FormerVendor
There is only one way to go! BETTER!
Old Oct 24, 2016 | 11:25 AM
Barnes 4wd's Avatar
FormerVendor
Keep those orders coming!
Old Nov 2, 2016 | 05:55 PM
Barnes 4wd's Avatar
FormerVendor
Old Nov 15, 2016 | 02:08 PM
Barnes 4wd's Avatar
FormerVendor
Introducing new parts every week! Check out our site if you haven't recently!
Barnes 4wd
Vendor Advertising
15
Nov 14, 2016 12:16 PM
Tofer
Dec 11, 2015 03:48 PM
kryptik
Jul 12, 2005 10:39 PM
