Tacoma Super Duty Transmission Mount
Old May 17, 2010 | 06:21 AM
traxman25's Avatar
4x Innovations has created the first true super duty transfer case/transmission mount for Toyota Tacomas! In this new mount the soft, weak, stock rubber portion of the stock mount is replaced with quality Energy Suspension poly round bushings. These bushings will not split and fail on you, relieving you of such worries associated with stock mounts. They are also strong enough to handle the worst conditions while eliminating your transmission and transfer case shifter slap. Your new mount comes with thicker steel plates that are laser cut and CNC formed for the best fit possible. This mount is a direct replacement. You can even run this mount with after market cross members that reuse the Toyota rubber mount.
As if all that wasn’t enough, there’s another trick feature to this mount. If you need remove your transfer case or transmission you now only need to remove two bolts from the bushings to pull the cross member down, not the 4, hard to get to, bolts that engage in the cross member.
Tacoma transmission and transfer case mounts fit 95.5-04 4 cylinder manual and 6 cylinder manual and automatic transmissions and come assembled ready to bolt on with a clean black zinc plate on the outside. They are $99 plus shipping.
To order please either contact us or click over to 4xInnovations.com and use the online shopping options.
Attached Thumbnails Tacoma Super Duty Transmission Mount-tacomount1.jpg   Tacoma Super Duty Transmission Mount-tacomount2.jpg
Old May 17, 2010 | 06:57 AM
yotarob2005's Avatar
Very nice, do you plan on offering them for different trucks, like maybe my 86 4runner in the future?
Old May 17, 2010 | 07:15 AM
traxman25's Avatar
They are, and have been for about 2 years, available for all gear drive transfer cases from 79-95! Check them out here.
Old May 17, 2010 | 12:59 PM
Sorry, I didn't mention that my 4runner has an automatic transmission. I didn't see one for the auto.
Old May 17, 2010 | 01:12 PM
traxman25's Avatar
Ah yeah no older automatic yet.
Old May 17, 2010 | 02:06 PM
Do you happen to know if they could be easily modified to fit an automatic or would it need to be completelly re-designed? I have full access to a machine shop & I am willing to cut, drill or weld if I have to.
Old May 17, 2010 | 02:12 PM
traxman25's Avatar
It's been a while since I have looked at the mount on a chain drive case but as far as I remember they are quite different. It could be something I will work on in the near future now that the Tacoma Mounts are done.
Old Jun 11, 2010 | 02:26 PM
traxman25's Avatar
I now have a limited quantity of the Tacoma Transmission Mounts in stock. Order yours today so it can ship Monday morning!
Old Jul 22, 2010 | 08:06 AM
traxman25's Avatar
These are in stock and ready to ship!
Old Aug 9, 2010 | 07:52 PM
aa1911's Avatar
how much stronger are these than the stock mounts, and obviously I don't expect any numbers but just a fair estimate in general terms; the reason I ask is because I am wanting to turbo the living crap out of my taco and will need a complete drivetrain upgrade and wanted to start now so I can focus on my engine upgrade when the time comes; looking for something that can reliably withstand something in the neighborhood of 400-500hp at least.
thanks, these look great btw...
Old Aug 11, 2010 | 07:58 AM
traxman25's Avatar
These use captive bushings in stead of a glued bushing, heavy gauge steel and two 1/2" bolts. I see you breaking other things before this mount!
Old Sep 22, 2010 | 08:28 AM
traxman25's Avatar
Bump to the top!
Old Oct 25, 2010 | 06:28 AM
traxman25's Avatar
Bump to the top!
Old Feb 18, 2011 | 08:06 AM
traxman25's Avatar
Bump for the Tacoma guys!
Old Jun 10, 2011 | 03:49 AM
4xinnovations's Avatar
Check out 4x Innovations' Super Duty Transmission Mount!
Old Jun 24, 2011 | 04:10 AM
Btt!!
Old Jun 30, 2011 | 05:14 AM
Super Duty Transmission Mount available at 4x Innovations!!
Old Jul 12, 2011 | 05:15 AM
Btt!!
Old Jul 21, 2011 | 05:15 AM
Check out this Super Duty Transmission Mount from 4x Innovations!
Old Aug 9, 2011 | 05:12 AM
Btt!!
