Tacoma/4Runner 2.4L/2.7L Mini-header kit now available!
#61
it looks like whoever provided the intallation photos never reinstalled the heat shield. was this for photo purposes only because they had reassembled everything above the heat shield?
#62
The heat shields are different between the two types of manifold/header. One would have to modify the manifold heat shield to fit the later header, so what people often opt to do it just use header wrap. I believe Scuba modified his stock manifold heat shield to fit the header.
#64
the shield is kinda of a pain to remove and inthe process i pryed the tranny dipstick out of position and lost the bolt that holds the dipstick into position. anyone know what size bolt i need to pickup to replace that?
#65
Just went and checked my tacoma. Sure enough, two decent sized cracks (Dammit!). Thought I heard an exhaust leak, was hoping it was just a collector gasket.
Does the mini header work on a 96 5 lug truck with a 2RZ? (I imagine it would).
#78
This arrived EXACTLY when it was suppose to , I would definately order again from this guy/company , everything was as described , don't hesitate to splurge on this . I Painted the headers a silver color with VHT paint and man does it look good , now all i have to do is wait on pb blaster to soak in to start this project . I am planning on modding my heat shield to fit this as well .
Ps . The only problem i have is the kit didnt come with the EGR gasket , for 325 dollars i think you guys should just put the egr gasket in there too. No biggie tho.
Thanks ......Mh
Thanks ......Mh
#79
Thanks ......Mh
Thanks ......Mh
