Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Serious Armor from RUFFSTUFF!!
Old Jun 27, 2016 | 03:23 PM
Gravel Maker's Avatar
FormerVendor
This is another one of our "million different uses" type products! Our Universal Tube reinforcements are meant to add wall thickness to your tubing ONLY where you need it! Great for tie rods, lower links, rock sliders, roll cages, and everywhere in between!
•Saves tons of weight and money versus building full sections out of heavy wall tubing.
•The bending and welding makes this reinforcement harder than the tubing it is covering! No more denting tubes.
•Replaceable! If you wear through the reinforcement simply cut along your weld to remove it and weld a new one on.
•Easier and stronger than cutting out and splicing in new sections of cage or rock sliders if a tube is punctured or scraped through!
•Fits on 1.5", 1.75", and 2"+ diameter tubing
•46" length is long enough to cover most full-width axle tie rods from tube insert to tube insert, 1-3/8" wide, 3/16" thick (makes your .25" wall tubing 7/16" wall!)
Universal Tube Reinforcement (Single) - RuffStuff Specialties
Old Sep 9, 2016 | 05:07 PM
FormerVendor
Beef it up BEFORE you bend it!
Old Sep 26, 2016 | 08:07 AM
FormerVendor
Armor up so your suspension can handle your excuse for a driving style.
Old Oct 8, 2016 | 10:24 AM
FormerVendor
Shin Guards for your links!
Old Oct 24, 2016 | 08:45 AM
FormerVendor
Never worry about your links again!
Old Nov 9, 2016 | 09:19 AM
FormerVendor
Extra Beef where it counts!
Old Nov 24, 2016 | 09:42 AM
FormerVendor
"Commander, activate lower link shields!"
Old Dec 28, 2016 | 11:58 AM
FormerVendor
Get the extra thickness where you need it!
Old Aug 15, 2017 | 02:21 PM
FormerVendor
Thick skin is a good thing in the offroad realm...
your-real-dad
Engine Swaps
Feb 24, 2016 10:44 AM
jbaums
Feb 9, 2016 11:45 PM
MudHippy
Feb 7, 2016 08:02 AM
Gravel Maker
RuffStuff
Feb 5, 2016 08:48 AM
