Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Ruffstuff Axle Simple Swap!!
Old Aug 31, 2016 | 06:38 PM
Gravel Maker's Avatar
FormerVendor
This is the basic kit essential for an Axle swap, more items could be added but this is the bare minimum, You will receive 1 pair of our 3/8" thick A50 Steel U-Bolt plates with 3 pin mounting options, a pair of our Spring Perches with the same pin option to match, 4 - 10" x 5/8" U-Bolts with 1/4" thick cut washers and real Ubolt Tallnuts, and a pair of Shock Brackets. This will get your Axle under the rig. BTW, this is NOT a Chinese made product that just can't hang with the big kids, this IS the Big Kid.
These go for $125 a kit before the Discount!
BTW, we have Ubolts that are the correct size for your axle, not 1 size fits all.......
Old Sep 17, 2016 | 11:34 AM
FormerVendor
Get the basic pieces that you can count on not to let you down, and are easy and straightforward to install!
Old Sep 29, 2016 | 03:50 PM
FormerVendor
Get all the pieces you need to bolt your axle up!
Old Oct 4, 2016 | 11:25 AM
FormerVendor
Ready to get lined up and burn home!
Old Oct 14, 2016 | 08:12 AM
FormerVendor
Its like stock stuff, only bigger, much much bigger...
Old Oct 31, 2016 | 10:36 AM
FormerVendor
Make the change and you won't regret it!
Old Nov 16, 2016 | 08:06 PM
FormerVendor
The right parts make the job easy!
Old Dec 26, 2016 | 03:15 PM
FormerVendor
Keeping it SIMPLE to make everyone's lives easier!
Old Feb 18, 2017 | 07:23 AM
FormerVendor
Putting in a new axle? Or just mounting the one that has served you well with stronger pieces?
Either way, we've got you covered!
Old Jul 23, 2018 | 06:14 PM
FormerVendor
Any axle.... made simple!
