Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
GETTING STUCK SUCKS - Offroad Recovery Packages w/ ramps & straps
Old Nov 12, 2014 | 05:00 PM
Total Automotive LV's Avatar
FormerVendor
Getting stuck is the worst feeling the the world. I was in deep Mexico once crewing for a trophy truck team using their Ford F350 4wd. Pulled over on the side of the road for a quick radio relay then began to drive again. The rear tires slipped so I put it in 4wd - IT WAS BROKEN! I was an open diff 1wd monster. I was totally dug in with no one in sight - had to wait several hours for another crew truck to come by and pull me out.
Dont let that happen to you! Ive put together 3 packages of products Ive used several times to pull trucks out (and back over) as well as these cool lightweight ramps that will get you out of even the stickiest sand. If you have special requests for straps, winches or other brands please PM me direct.
SmittyBilt Recovery Kit - 203.95 delivered
2x All Element Traction Ramps (S/B2790)
1x 3" x 30ft Recovery Strap (S/BCC330) 30,000lb rated
1x Receiver mounted tow hook (S/B7610)
ARB Recovery Kit - 302.56 delivered
2x ARB BushRanger Sand Tracks (ARB54X07)
1x ARB 30ft Snatch Strap (ARB705)
ARB Recovery Kit Ultimate -
623.68 delivered
2x ARB54X07 BushRanger Sand Tracks
1x ARB501 Recovery Bag Large
1x ARB705 17,500lb Snatch Strap
1x ARB730 26,500lb x 10’ Tree Trunk Protector
1x ARB720 9,900lb x 66’ Winch Extension Strap
1x ARB220 Recovery Damper
1x GLOVES Leather Recovery Gloves
ARB207D 10,640lbs, 3/4” Pin, D-Shackle
1x 10100020 Snatch Block 9000
See all kits here
Click kits above to view more info, add to cart and enter code YOTATECH for forum discount!!
Delivery in 2-3 days.
Redeth005
Jun 28, 2018 08:16 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
Motomonty
Aug 9, 2015 05:53 PM
Yoda
57
Jan 6, 2004 03:10 PM
UKMyers
21
Jan 6, 2003 04:19 AM
