Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Fresh Upgrade: NEW Morimoto XB LED Headlights with Sequential Turn Signals
Old Mar 14, 2025 | 02:11 AM
carid's Avatar
Premium Sponsor
Since its founding, Morimoto has taken a different approach to lighting upgrades, creating not only highly functional solutions but also adding unique touches to each set and offering a myriad of configurations to choose from. In today’s post, we’ll take a closer look at the XB Sequential DRL Bar Projector Headlights designed for your hardworking 2014-2025 Toyota Tundra.
Powered by LEDs to offer unsurpassed illumination and to create precise beam patterns with exceptional width and intensity, they provide maximum visibility when you leave the pavement and help spot obstacles, machinery, or workers in dimly lit areas. The lights also feature a row of amber LEDs, which can operate in either sequential or solid mode, depending on your preference. Sequential signals create dynamic movement, making it easier for other drivers to notice your turn signals faster. The advanced, sophisticated optics of the headlights are guaranteed to meet and exceed all SAE, DOT, and FMVSS108 regulations. Morimoto headlights come with sealed housings to prevent moisture and dirt buildup and feature wear-resistant lenses and durable housings to maintain their clean look for years of continuous use.
Morimoto® - XB™ Gloss Black Sequential DRL Bar Projector LED Headlights
Includes:
  • (2) LED Headlights;
  • Plug and play wiring harness;
Specifications:
  • Bulb type Osram LED
  • DRL/running light color amber;
  • Turn signal color amber;
  • Operating voltage 9-32V DC;
  • Functions LED DRL, sequential turn signal;
  • Lens material UV-coated polycarbonate;
  • Housing material polycarbonate;
  • Optic Bi-Kuria LED Optic;
  • UV coating momentive UVHC3000;
  • DOT, SAE, FMVSS compliance;
  • Left hand traffic;
The XB Sequential DRL Bar Projector Headlights come with a direct-fit design that plugs into factory wiring. No extra cutting or splicing is needed.
Old Mar 14, 2025 | 02:45 AM
carid's Avatar
Premium Sponsor
To enhance your visibility even further choose the additional auxiliary lighting options from our immense selection of lighting upgrades.
Also, you can read more about the manufacturer at CARiD: https://www.carid.com/morimoto/
carid
Vendor Advertising
Nov 18, 2024 03:32 PM
lee
42
May 6, 2004 06:22 AM
