Yota 87 Solid Axle Swap
Old Sep 7, 2003 | 08:59 PM
lcopelan22's Avatar
Hey ya'll. I recently swapped an 85 front axle into an 87 yota. I finished a week ago. First, I want everyone to know that I completely had the IFS out and completely ground in ten hours -- with a socket set, $50 dollars off sawzall blades, and cutoff disks -- and no Cutting torhch at all !!! This project is much easier than you would think. The axle went in with no problem and with no air tools. I'd say the swap took about 15 hours with minimal tools. Unbolt everything off the IFS and "JUST START CUTTING". I used all pro offroads frame sleeves, brakelines, and cross over steering. I also used some superlift 3'' recurve springs. I took it out and flexed it hard, and everything worked perfect. I am running 2K old BFG Mud's and didn't need 17.5'' clearance from top of fender to tire top so decided to use stock Front YOTA springs off an 81. HUGE MISTAKE!! The pitman Arm was about an inch off the tie rod giving me like 1'' of flex in the front. How about 4 hours of work that totally did nothing. Today I was out to fix it though, I went to my buddy who has helped me through all off this and we went back to the 3'' recurves. We decide to shim the front axle 8 degrees before mounting the springs. All said and done it looked ok under a flood light in a driveway. ON the ride home it was awful though. Upon returning home I noticed that my tie rod was touching my springs. The same setup minus the shims gave me like 3-4 '' of clearance between tie-rod and springs. What could happen next????? If I would have left it alone yesterday it would still be fine!!!!!!!! If anyone has any ?????'ss on the SAS swap feel free to E'mail me. I think I have had more trial and error headaches than anyone on this thing and would be more than happy to help a buddy out........ PS. we shimmed the front so the diveshaft would hook up. Luke Copeland.....
Old Sep 7, 2003 | 10:25 PM
Robinhood150's Avatar
Cool, welcome to the board. We need pics!
Old Sep 7, 2003 | 11:12 PM
Shane's Avatar
Re: Yota 87 Solid Axle Swap
Ouch! That's a lot of blades and disks! I think I'll stick to my plan of using a plasma cutter, thanks. Where's the pics?!?!
Old Sep 8, 2003 | 06:33 AM
Albuquerque Jim's Avatar
Picccs!
Old Sep 9, 2003 | 09:13 PM
upndair's Avatar
You can't just shim the front end like you do the rear. This will screw up your caster big time!
To angle the pinion up on a solid axle, you have to cut and rotate the knuckles on the housing. Simply shimming alone will create a horrible alignment problem.
Old Sep 10, 2003 | 08:42 AM
INsr5runner's Avatar
wanna Help me SAS my 2000?
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
gieselman
Oct 12, 2015 01:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
scottyg486
Jul 19, 2015 05:34 PM
