Why is the Warn M6000 more expensive than the M8000
Co-Founder/Administrator
Depends on where you buy it.
Warn M6000 with roller fairlead
$583.95
http://www.central4wd.com/inventoryd...folder%7C15602
Warn M8000 with roller fairlead
$699.95
And here is a M8000 with Hawse fairlead
$626.95
$583.95
$699.95
$626.95
Probably because they don't sell as many.
The M6000 isn't big enough for our trucks. You need AT LEAST an 8000, and even then you should be double line pulling most everything (run the line through a snatch block and back to the vehicle to double the pull strength).
I have almost stalled a 9500 with Molly's truck, even had it working REALLY hard with a double line pull.
Here's the link
Summit Winch
Is your statement 100% true?? That's a good winch (if true) for the price!
EDIT - Clicked on the "Instructions" PDF and it comes up as a T-Max. Nice find!
Summit Winch
sonorn67
Sep 19, 2015 05:39 PM
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
Sep 3, 2015 09:01 PM
