Why IFS blows???
Old Oct 3, 2003 | 01:52 PM
  #81
crawler#976's Avatar
ahhhh, Z-Rock on Lower Terminator that's a left front marker light eater
Old Oct 4, 2003 | 06:40 PM
  #82
ravencr's Avatar
Yeah, that's sweeeet!
Chris
Old Nov 8, 2003 | 02:09 PM
  #83
outdoorfever's Avatar
so by reading all these posts, should i get SAW's? right now i have stock t bars and i am afraid that i might hurt my cv joints if i tighten them too much. thanks ~KyLe
Old Nov 8, 2003 | 02:51 PM
  #84
Flygtenstein's Avatar
Don't waste your time or money on Sway-Away torsion bars unless you have three or four fat guys on your front end. You will lose travel, kill the ride and basically piss away 100 bucks.
And as long as I am replying, that Camburg kit makes all other IFS stuff look silly. Too stiff, hardly. Not what I would do for what I wheel, but it looks to work all right for Fear.
Old Nov 8, 2003 | 03:57 PM
  #85
ravencr's Avatar
Could it be that his spring rates are too high with the camburg kit? It seems to me that this would be one highly probable factor to making that long travel kit be stiff with little flex.
Chris
Old Nov 28, 2003 | 08:58 PM
  #86
Originally posted by Mad Chemist
Yeah, I'm thinking Camburg's got the front set up waayyyy too stiff- Steve Schaeffer would spank that rig...
Steve would spank me?
Hay Steve would you kiss me before you Spank me?
Dont judge my rig from that one pic. My rig is a 4 door fam wag. Its not a SAS rock rig. (as much as i would like to cut it up and tube it and SAS)
It works ok. ya my rig didnt have a lot of kool droop or comp. but the frnt and rear together work "ok" . Its one of the things you need to see for yourself.
Hay Steve we need to plan a trip to AZ.
here are some more pics of my p.o.s.
Old Nov 29, 2003 | 05:37 AM
  #87
ravencr's Avatar
That looks pretty good to me, and possibly better than anyone else that has post yet. Feartoy, do you know what kind of springs rates you are running up front?
Chris
Old Nov 29, 2003 | 05:57 AM
  #88
Chris I don't know what spring rate I have but i will try to find out for you guys.
Old Nov 30, 2003 | 09:20 AM
  #89
sschaefer3's Avatar
That would be nice. It would be interesting to see how you do over here.
Fear has his vehicle set up very well for the areas he goes to. I have mine set up for the areas I go to.
They are not the same, I never have a need to go fast. He does.
Old Nov 30, 2003 | 05:41 PM
  #90
RTdawgs's Avatar
recent pics of my IFS
Old Dec 3, 2003 | 01:41 PM
  #91
Korrupted's Avatar
1. no travel
2. weak axles
3. weak tie-rod ends
4. idler arm
5. a-arms
6. smaller gears
Old Dec 3, 2003 | 01:56 PM
  #92
44Runner's Avatar
Originally posted by AzWildYoat
1. no travel
2. weak axles
4. idler arm
5. a-arms
6. smaller gears
yup, that about sums it up...
#4 should be idler arm/steering rack to cover the newer trucks...
Old Dec 4, 2003 | 08:34 AM
  #93
flecker's Avatar
From: White Mountains, Arizona (Yes it does snow in AZ)
I have both ifs and a solid axle rig, they both have different good and bad qualities about them. IFS doesn't suck, it's just limited in travel. It's way more comfortable to drive, more stable, and can take a little abuse. Solid axles can flex well, this is true... but they suck at speeding down a desert washboard road! Just get one of each and have the best of both worlds!
Old Dec 4, 2003 | 10:22 AM
  #94
actually, w/ 14" of SAS'd soft spring travel, I tend to motor right along on washboard stuff. The 6" of up travel does a pretty good job of absorbing impacts, and 8" of droop follows the contures ok.
The licence plate on my rig is SloYota, but that pretty much only applies to the hi-way. The 22RE, 35's and 5.29's will get me up to 62 MHP or so most of the time
Old Dec 4, 2003 | 01:37 PM
  #95
Korrupted's Avatar
IFS and IRS is the best thing ever invented for pavement pounders but for real off-road it really Blows!
Old Dec 5, 2003 | 06:49 PM
  #96
init6's Avatar
Yea...IFS really blows for desert racers.
Old Dec 8, 2003 | 01:40 PM
  #97
Korrupted's Avatar
Sorry, let me clarify that. IFS really blows for real off-road vehicles, I.E. rock crawlers
Old Dec 8, 2003 | 02:28 PM
  #98
flecker's Avatar
Aw hell... I tried to be nice earlier in the posting by pointing out the goods and bads of each. IFS is ok, just limited... I have seen some IFS rigs (mine included) do some pretty amazing things, albeit scarier than shizzle at times. A solid axle has the ability to out flex an IFS any day of the week, and is way more capable in alot of situations... IFS does not however totally suck; ergo alot of good can be found in the setup. How many of you have busted a birfield??? What a huge PIA!
puddlepirate
Jul 30, 2016 06:29 PM
4banginRunner
Nov 13, 2015 05:23 AM
dirk89
Oct 1, 2015 05:15 PM
bryan34w
12
Sep 30, 2015 02:50 PM
Scotttekoch
Sep 28, 2015 10:30 PM
