What gears should I get?
Old Oct 27, 2014 | 08:32 PM
dropzone's Avatar
Fossilized
I have had several trucks over the years.
stock 4.10's with 33's, 31's
4.88's with 33's -35's
Currently dual t/c with 5.29's and 35's
Even with 5.71's and 35's no way you would only be going 25 in 5th gear in high range.
Plug your numbers into a gear calculator like this
https://www.marlincrawler.com/java/getspd_calc.html
Old Oct 28, 2014 | 05:30 AM
bobbyd1989's Avatar
Yeah something's not right, sounds like something wasn't put back together just right. Gears are a tricky skill to master because everything has to sit just perfect for it all to work in sync. 1/100 of an inch off and you could start having the gears teeth start to get all chewed up. I have 5.29's with 35's and I can run 60mph with no problem. Even though it says you are in 2wd are you sure your not stuck in low range? If you put it in low range does it rev even higher?
Old Nov 5, 2014 | 04:44 AM
88ECToy's Avatar
Yup, 4.88 on 35's here. Something funny going on here. How did you get the new ring gear back on?
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
