what is the best front locker for an 86 yoter
Old Nov 4, 2008 | 08:13 PM
83 stump jumper's Avatar
what is the best front locker for a 1986 toyota pickup?
Old Nov 4, 2008 | 08:21 PM
bigarms23's Avatar
lockrite or aussie
Old Nov 5, 2008 | 02:01 AM
914runner's Avatar
An Aussie should work well for you.
Old Nov 5, 2008 | 03:33 AM
akaphilly's Avatar
the best is definitely the ARB air locker. but its pricey
Old Nov 5, 2008 | 04:10 AM
dropzone's Avatar
Fossilized
selectable locker
it is what I have but locked front ends can bind when turning (=breakage) Sure you can get out and unlock a hub but that sucks..twinsticks fix that..
are you doing to be driving this thing on snow covered roads in 4x4? Locked front ends drive totally different.
What is the best comes down to your budget. Selectable is the way to go if you can afford it. ARB Air Locker....Toyota is second but not sure if they made one to fit the 7.5"
Old Nov 5, 2008 | 07:13 AM
AxleIke's Avatar
The best is hands down an ARB Air Locker. Absolutely no competition.
However, most balk at the cost. So, if you are on a budget, an aussie or lockright will work. But they are far from the best.
Old Nov 5, 2008 | 09:06 AM
tc's Avatar
tc
The only lockers without performance compromises are the selectables. For IFS, that means ARB as an elocker won't work.
ALL the other options trade on-road performance for off-road or vice versa.
For example: a trutrac limited slip is FANTASTIC on road, but worthless when you lift a wheel offroad. Welded is great offroad in slick conditions, but you won't be able to turn (AT ALL) on road (with the hubs locked).
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
jaretstuff
Aug 4, 2015 02:08 PM
coffey50
Jul 28, 2015 10:55 AM
