Welding Rear end?
Old Oct 7, 2008 | 04:33 AM
80yotaman's Avatar
Welding Rear end?
Im a good welder, and i was wondering is there any special technique that i would need to do as far as welding the spider gears up in a toyota 8" rear end. Need some answers quickley, Any advice would help out alot, Thanks
Old Oct 7, 2008 | 04:47 AM
WFO's Avatar
WFO
I just did mine a few weeks ago. I put the whole third member in my grill and let it sit in there for about 10 mins or so (about the time it took to get everything set up and ready) then just welded the gears where the come together. Just take your time and go slow. Then when its done put it back in the grill and let it cool slowly.
Ive seen a lot of different ways of doing it. Like filling all the teeth in so the gears cant move, welding a piece of flat bar onto the teeth or even welding another spider gear onto the gears.
But so far so good for mine just welded together.
Old Oct 12, 2008 | 12:08 PM
n16ht5's Avatar
do a complete job and make sure you weld the spider gears to the outside and not just to eachother.
clean out the slag... it will ruin your seals if you dont
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
hangtown88toy
Jul 10, 2015 02:33 PM
crashburnoveride
Jul 10, 2015 06:39 AM
akaphilly
Jul 9, 2015 02:18 PM
