Vibration When down shifting after 63" spring instal
Old Jun 1, 2018 | 07:42 AM
Wadam30's Avatar
So I just recently did the 63" spring swap on my 1987 runner and everything flexes beautifully and rides as should be expected, however, I am experiencing a slight vibration when down shifting. I've been under there countless times make sure everything is tight. lined up properly, measured correctly etc. The only thing I can think of is I have the interior pretty much gutted and there's not that much weight (not that interior adds that much weight anyway) and could be the tires chattering. Any ideas? Your guys' advice is always appreciated. Thanks!
Old Jun 8, 2018 | 08:37 PM
Punchy's Avatar
What are the driveline to diff angles, During downshift the diff pulls downward and could be binding the Ujoints.
Last I read 3 deg optimal, 7 deg max and should be same on both ends unless you have a dbl cardan on one end.
Quinn's87RE
Aug 8, 2019 09:54 AM
Wadam30
Jun 1, 2018 07:30 AM
shadowcat
Jan 21, 2009 03:28 PM
warriors_03
Jan 12, 2008 08:53 AM
