trailmaster kit???
Old Dec 15, 2007 | 06:00 PM
krentigrboi's Avatar
trailmaster kit???
can you fit the 90-95 4runner lift kit on to a 01 4runner??
Old Dec 15, 2007 | 06:50 PM
colsoncj's Avatar
I would doubt it... the two styles are significantly different.
Old Dec 15, 2007 | 07:19 PM
98sr5tacoma's Avatar
no................................................ ..........................pe
Old Dec 15, 2007 | 08:20 PM
DeathCougar's Avatar
not a chance. Totally different suspension setups.
2nd gens use a Torsion bar front suspension
3rd gens use a coilover front suspension
Old Dec 15, 2007 | 08:36 PM
colsoncj's Avatar
How much difference is there in the rear though. Agreed the front is entirely different, but both rears are coiled with panhards, right?
Funny thing, I should just go look, I have a 3rd gen sitting in my garage and I remember what a second looks like. I just wasnt sure whether he was refering to some trailmaster rear lift kit utilizing spacers or the like which may work on 2nd and 3rd gen 4runner suspensions. I guess I should have clarified the "i doubt it."
Old Dec 16, 2007 | 05:44 AM
waskillywabbit's Avatar
No and why would you want to?
Old Dec 16, 2007 | 07:21 PM
deserttoy84's Avatar
Unless 2001 is the new 90s and you got a custom one off torsion bar 4 runner manufactured in 01 then it wont work
Old Feb 15, 2008 | 05:23 PM
yotapwr's Avatar
I need some info on trailmaster lifts!!!
Old Feb 15, 2008 | 05:29 PM
fillsrunner4's Avatar
X1,000,000
Old Feb 15, 2008 | 06:09 PM
uhhhh..........Ok?
Old Feb 16, 2008 | 05:27 PM
BajaRunner's Avatar
He's got reasons. As do I.
Yeah, If I had the money I'd love to build up a 'true' offroad rig. But, since i don't, and I just need something to get me around but also get me into Baja for camping and get through thick sand and mud, its perfect for my application!
Old Feb 16, 2008 | 06:14 PM
JohnnyRanger54's Avatar
heeeeeeelll no.. different suspension holms.... just scrap the 2001 and giv it to me and find yourself a 2nd gen to use the lift on...
Old Feb 21, 2008 | 08:07 PM
elripster's Avatar
Just so you know, that lift will not help you with any of those goals. Lockers, gears and tires, however, will. You'll need some clearance to fit a 33X12.5" tire but that can be done inexpensively and durably with other options.
You can fit a 32X11.5 more easily and it will float well on sand. Ad the 3rd gen E-locker and you are there.
Frank
Old Feb 21, 2008 | 08:18 PM
BajaRunner's Avatar
Frank
Dude, I've been traveling into Baja my whole life. I know exactly how and where stock vehicles will get stuck in compared to a lifted application with larger tires.
Half of the trails are pretty quick roads, you bottom out every 5 seconds. The other will be thick mud, loose moon-dust, thick sand, etc. 35's and having a higher clearance is pretty important, as I have both.
Yeah, I hear you lockers and tires are important.
Old Feb 22, 2008 | 06:27 PM
elripster's Avatar
We are talking about vehicles with tires, gears and lockers which are not stock though.
The clearance for the tires is important, however, the rest is not in the situations you have described. You'll be on your axles long before the body contacts anything.
Sounds to me like you might be a good candidate for a long travel kit. They aren't cheap but work really well in the situations you described.
Frank
Old Feb 23, 2008 | 02:38 AM
James Dean's Avatar
Do you know someone selling a kit cheap?
viesail
Sep 21, 2015 06:00 AM
Adam Edgar
Sep 20, 2015 03:24 AM
sonorn67
Sep 19, 2015 05:39 PM
JookUpVandetti
Sep 17, 2015 09:25 PM
Patrick1976
Sep 15, 2015 11:33 PM
