Om617 4runner Axle Ratio
Old Dec 25, 2011 | 05:14 PM
nicholasm40's Avatar
What size gear ratio should I use with my swapped Mercedes 5cyl turbo diesel? Im leaning towards 4.88's with 31's and will be getting some 33's soon along with a rear locker. But I need some opinions on gear size 1st!
Old Dec 25, 2011 | 06:19 PM
ThatGuy1295's Avatar
whats that engines best cruising rpm?
Find out where it needs to be at 65mph. Wouldn't worry about anything else with a diesel.
You definitely don't won't to high of rpm's.
Old Dec 25, 2011 | 07:01 PM
It's very similar to the 3.0 that was in it as far as RPM range and such for cruising and what I could find on what that motor cruises at. But I don't do hardly any Highway driving where I get over 60mph.
Old Dec 25, 2011 | 07:07 PM
In that case id definitely go 4.88. As long as that diesel can run at 3,000rpm safely, if you ever did need to go 65mph.
Old Dec 25, 2011 | 07:16 PM
oh it'll run the 3k no problem, with that motor it has tons of torque over that 3.0 I had. lol Thanks for the help bud!
Old Jan 9, 2012 | 06:30 AM
44Runner's Avatar
I run 4.30s in my 4Runner on 33s with the 3.0 5sp and it does fine. I threw them in because I had them already and didn't feel like spending more money for new gears. If money wasn't I factor I would have gone lower of course. Basically what I am saying is on 31s and that power plant I wouldn't be overly worried about your gearing just yet if you have other things on your plate to get the truck done. Gears could easily come later if you happen to have budget issues. Drive it with stock gearing and figure out from there.
icentropy
Sep 16, 2020 02:47 PM
jerusry
Oct 19, 2015 05:28 PM
smiley52
Jul 11, 2015 05:16 AM
ItsJustD
Jul 7, 2015 07:49 AM
toyoda8488
Jul 5, 2015 10:18 PM
