My IFS rig need advice
Old Jan 22, 2007 | 04:22 PM
Stomis's Avatar
Hi all I am a new here and noticed you guys have a great database going.
My rig entails:
Overall
1995 ext Cab Pickup
3.0L v6
5-Speed Stick
2" 4crawler body lift
33x12.5 Goodyear Wrangler AT/s' on 15in rims
Front Suspension
4.56's
1.5" BJ spacers
Torsions cranked for 1.5"
Nitro Skyjacker shocks rated for 3-4" lift
Diff breather
swaybar delete
Rear Suspension
Yukon 4.56's
Richmond locker
3" blocks with sagging leafs :-X
Crappy advanced auto shackles (getting replaced asap)
Diff breather
Plans
Total Chaos Fab Idler arm
Snorkel
Warn Manual Hubs
Aftermarket Torsion bars
Brace from Sonorma (sp?) steel
water proofing
My biggest concern is what else I can do to prevent IFS breaks. I just recently snapped my Idler arm on the trail which in turn threw my axel bearings out on the ride home. I want to beef things up but not go dropping too much money only beause theres a SAS in the distant future hopefully.
Old Jan 22, 2007 | 04:33 PM
AxleIke's Avatar
you can drop the suspension back to stock with the BJ spacers (uncrank tbars)
In addtion, smaller tires would help.
Other than that, the steering on these trucks is so crappy that just about any change from stock starts to have it crap out. The new trucks have a much superior system to the ones on these old trucks.
Good luck
Old Jan 22, 2007 | 04:36 PM
Stomis's Avatar
Does a Tacoma hold the same steering as far as tierods gos? Possibly a junkyard swap as an option to beef all the links in the ifs tierod?
Old Jan 22, 2007 | 04:42 PM
AxleIke's Avatar
no, the steering on these early trucks is standard mechanical. So, pitman, idler, center link, tie rods etc...
The new ones use a rack and pinon style. A swap would cost way more than its worth, as you'd need either new spindles or some creative fabbing to move the steering behind the front suspension.
Old Jan 22, 2007 | 04:46 PM
Kyle95sr5's Avatar
Idler Arm Brace
https://www.yotatech.com/forums/show...dler+arm+brace
Old Jan 22, 2007 | 05:06 PM
Stomis's Avatar
I realise they make a brace for it but the total chaos idler arm appears to use grade 8 hardware instead of a casted stud which would mean should something break I can carry a 2dollar grade 8 bolt and wahla idler arm is now fixed.
Besides I'm not really seeing the major help given by that gusset. it grabs the arm and gives it more area to hold but should I break it its still broken. Perhaps I'll use it til i save for the Total Chaos Arm.
PS: Wats the price on that brace??
The other thing i want to discuss is my tire size. Is the 12.5 wide factor contributing to the strain on my IFS? When I get my Wrangler MT/r's should I go for 33x10.5? What about 35x10.5 litle bit overload?
Old Jan 22, 2007 | 05:09 PM
Elton's Avatar
also may want to get rid of those blocks
Old Jan 22, 2007 | 05:18 PM
Stomis's Avatar
Yeah I plan on getting some different leaf packs from somewhere...
Old Jan 22, 2007 | 06:22 PM
Stomis's Avatar
Tomorrows game plan is to level out my torsion bars to the 3" lift in the rear. I have the 1.5bj spacers as I said so I'm going to bring the front up about an inch to acheive 1" from tbars and 1.5" from BJ spacers. I'm going to pickup lowprofile bumpstops to make up for the inch of downward lost and leave my top bumpstops alone.
Starting to read that I should only put low profiles ontop due to cv's on droop. Any truth to this?
Old Jan 22, 2007 | 06:48 PM
AxleIke's Avatar
get the chaos arm...wayyy better than the brace. Its not so much the arm bending, its more the joint at the end failing. The chaos arm is the shiznit.
With that much cranking, there really isn't a point on the tires. Run what you like.
CV angle is going to be affected by the top bumpstop, which is what limits your down travel. Low pro bumpstops up top plus BJ spacers will give you issues on full droop.
Old Jan 22, 2007 | 06:58 PM
Stomis's Avatar
Alright so droop is obviously when your suspension hangs / move downard. I dont get how the top bumpstops limit this. I would think that top bumpstops limit upward travel and lower bumpstops would limit droop/downward travel. Is there a diagram or picture that could help explain this because right now I'm not understanding.
Say my axles are at droop wont my lower A-Arm be caught on my lower bumpstop or am I thinking they are mounted differently than they are?
Old Jan 22, 2007 | 07:01 PM
Stomis's Avatar
Ah I got it this picture just spelling it out. I was thinking the bumpstops were stationary but rather they move with the a arm. So just do the bottoms got it.
Old Jan 22, 2007 | 08:45 PM
AxleIke's Avatar
No.
Bumpstops are stationary. Droop is limited by the upper bumpstop, which stops the upper A-Arm from moving downward any farther. Uptravel is limited by the lower bumpstop and prevents the lower arm from moving up any farther.
Pics:
Lower bumpstop just above lower A arm, limiting up travel.
Upper bumpstop sitting just below upper A-arm, limiting droop.
So yes, in order to protect cv's, you'd only want low profile on the bottom.
Old Jan 22, 2007 | 09:23 PM
anthony1's Avatar
If you plan to go SAS, don't throw any more money in the front suspension.
That's the route I took anyway.....
Old Jan 22, 2007 | 10:18 PM
Blizzard's Avatar
x2
I've a solid front axle sitting in my garage to the swap, and now I don't have enought money to do it... If only I hadn't put so much momey in something I was goint to cut... Do whatever you want to do from the begginning.
David
Old Jan 23, 2007 | 04:26 AM
Stomis's Avatar
Well the thing is I realised the SAS will never happen. Even if I do get the money I'll never be allowed to pull my truck off the road and dump $3000 all at once into by the parents. Therefor the IFS beefing begins...
Old Jan 23, 2007 | 09:39 AM
CanTheWhales's Avatar
Originally Posted by AxleIke
Sorry, but is that ice...?
Old Jan 23, 2007 | 09:44 AM
AxleIke's Avatar
You bet. 5 degrees last night when i took that pic. Snowed the day before...you drive through some snow, and then it doesn't melt.
Old Jan 23, 2007 | 09:46 AM
mastacox's Avatar
Definitely go with the Total Chaos Idler Arm over a brace, you'll break something else on your steering before you break it (probably an adjusting sleeve or TRE). Keep in mind you will have to drill your drag link to fit the far larger bolt on it, just a warning. Might see if your truck is covered under the recall on those before you drill it for the TC arm. Then, just keep an eye out for weak links in the steering, and upgrade/replace them as they break.
As for CV's, I would go with cheap-o Autozone or Checker stock replacements with lifetime warranties. Heck even buy some spares. They are only $70 with a core, so breaking one is no bigge, and they can be replaced for free under warantee.
Also: make sure you get the Warn "premium" manual hubs. The regular ones supposedly break (if you can even get them for your truck... I've never seen a set of Warn regulars).
Old Jan 23, 2007 | 09:57 AM
Injohneer's Avatar
Unless you really go through cars fast, you'll have your Yota long after you're done living with your parents. Then you'll be wishing you didn't spend a lot on IFS if you decide to SAS.
A couple more points to ponder: Do you want to mod forever without limits (except $), or do you want to keep your truck with the basic Toyota design for that year/model?
A lot of people are proud of their Toyotas, but only the sheetmetal is a Toyota by time they're done. So it might as well have been a Jeep or anything else.
There's also something to be said for driving with less "built" equipment, to hone your driving skills before you build up. Your well SAS will last longer if you learn to be gentle with an IFS.
