Mounting CB antennas in door jam
Old May 14, 2009 | 07:42 AM
4runner901's Avatar
is it okay to drill above the tail light?
where do those screw go?
Old May 14, 2009 | 08:05 AM
algranger's Avatar
Would help to know what vehicle your talking about.
Why dont you just take the light out and look up in there?
Old May 14, 2009 | 08:22 AM
claudebadly's Avatar
on a 00 taco there isnt anything above the light, those screws -assuming you are talking about the tail light mounting screws- just go into plastic holders that are placed into the sheet metal of the bed.
Old May 14, 2009 | 08:33 AM
scuba's Avatar
Judging from the name im guessing 4Runner and between the rear hatch..
Old May 14, 2009 | 12:23 PM
4runner901's Avatar
im talking about on a 95 4runner in between tailgate and the tail light area
and i know you can take tail light off and screw through there and and see where the screw goes, BUT i've seen people mount the door jam mount above the tail light. where do those screws go? is that bad to do?
Old May 14, 2009 | 02:12 PM
4runner901's Avatar
anyone?
Old May 14, 2009 | 03:23 PM
4runner901's Avatar
no one knows?
Old May 14, 2009 | 08:12 PM
rhale's Avatar
on my 89 if you take the taillight out you can reach all the way up to the bottom of the side rail. i have mine mounted in between the tailgate and side have no issues. just take out taillight and look or feel behind where you want to mount it. be sure you drill small pilot holes to start and then step up to the size you need for your mounting screws.
Old May 15, 2009 | 07:32 AM
4runner901's Avatar
yeah i know what your talking about but ive seen people mout them above that tail light, and i dont know where those screws go?
anyone help me?
Old May 16, 2009 | 12:21 AM
Blizzard's Avatar
I won't put the antenna there. The ground plane (Don't know if that's the name in English) will be the trucks roof, so you'll have half of your antenna wasted...
Best place is front bumper (If you've an aftermarket one) or the roof.
I've my antennas on the front bumper.
David
Old May 16, 2009 | 05:23 AM
jeremy9allen's Avatar
check this one out https://www.yotatech.com/forums/f2/c...w-pics-180012/
Old May 16, 2009 | 06:42 AM
cootees's Avatar
I mounted mine like you are questioning. There is no right or wrong place to put the screws just hold up the bracket to it and see where you want to put it.
Old May 18, 2009 | 07:26 AM
4runner901's Avatar
yeah but what about the body?
are those screws bad for it when you drill them in?
becasue like you did it, you just drilled it in to no mans land it looks like
but if you go lower, you can take the taillight off and see the screws come through
but when you mount it about the tailight
where the poop do the screws go?
Old May 18, 2009 | 08:05 AM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
He has a bracket going in between the tailgate and the body. Dont know how hes got that attached but screws shouldnt be a problem as long as they are strong enough.
Old May 18, 2009 | 09:15 AM
cootees's Avatar
I believe I used self tapping screws. Can't remember.
It's been on there for a couple of years now.. the screws did not hit anything, it is dead space above the taillight and it works fine. Many tree limbs have been hit by the antenna.. but that is what the antenna spring is for.
If you are so worried about drilling holes through your 4runner then you can always get a magnetic mount and slap it on your roof.
Old May 18, 2009 | 08:07 PM
4runner901's Avatar
okay cool
so drilling up there (above the taillight) isn't a big issue?
Old May 19, 2009 | 02:40 PM
4runner901's Avatar
okay cool
so drilling up there (above the tailight) isn't a big issue?
Old May 19, 2009 | 07:55 PM
4runner901's Avatar
so drilling above the tailight isnt a big issue?
Old May 19, 2009 | 08:02 PM
94Runner4x4's Avatar
I would say it's not. Mine is on the left side in the middle of the light, been there for 2 years and never had a problem.
westonian18
May 1, 2020 06:38 AM
mussy01
Dec 13, 2016 08:20 PM
theking11863
Mar 19, 2016 09:36 PM
TDonkey
Jul 26, 2015 10:14 AM
britishdudes2dr
Jul 25, 2015 06:47 AM
