manual hub gaskets
Old May 16, 2004 | 05:49 AM
wvuviv30's Avatar
manual hub gaskets
I am looking at getting a set of used hubs. but is there a gasket inbetween the looking hub and spinder assembly?
if so what is the part number for it? Fel-pro, Toyota, ETC. or do I just use a small amount RTV sealant.
Also what size is the bolts on the hubs? I know their metric, any one ever measure them.
Old May 16, 2004 | 10:43 AM
toy283's Avatar
Not sure exactly which gasket you are asking for but:
The manual hub is attached to the wheel hub by six metric studs M8-1.25×~20mm (Toyota p/n 90116-08325) and six cone washers (Toyota p/n 42323-60010). You cannot use bolts in place of these studs. The manual hub cover is held to the hub by six small M6-1.00×~10mm bolts (no Toyota p/n available).
Old May 16, 2004 | 12:45 PM
Yoda's Avatar
That "unknown " gasket is pt # 43531-60010 (at least for an 88 fj60, but it should be the same) There is also a "square" shaped O ring that seals the middle selector part from the outer stationary part. I'll post that # when/if I find the receipt in my car.
I wouldn't want to use silicone seal in the hubs. Might get inside and gum up the works.
Old May 16, 2004 | 04:31 PM
wvuviv30's Avatar
Thanks... I think you re-use the orginal nuts holding on the ADD crap... but I should be able to find the gaskets now....
Old May 21, 2004 | 09:50 AM
Highland Runner's Avatar
I would go ahead and get the "square" o-ring also. I've bought 2 sets of hubs and both sets the o-ring was cracked/dry rotted. The dealer closest to my house has never had either gasket or the o-ring in stock. Wonder if any Nissan or Suzuki dealer carries them. Who sells Suzuki's now anyway?
Old May 28, 2004 | 08:08 PM
wvuviv30's Avatar
the O-Rings where good.
Advance Auto and AutoZone didn't even have the part. they even crossed referenced the part numbers. well Advance Auto pulled up RTV sealant. so I used a small amount of RTV sealent.
kgcwb44
Jan 29, 2023 10:02 AM
oldirtydirt
Feb 23, 2020 09:30 AM
PlayAwhile
Jul 20, 2015 11:36 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
ItsJustD
Jul 7, 2015 07:49 AM
