Lunchbox locker options for a 2000 Taco
Old Dec 6, 2004 | 01:24 PM
Fergie's Avatar
Okay, so I'm an XJ guy over from the Jeep boards and I have got to say, that from all my searching on this site, that you folks are pretty darn polite, so good on ya!
Now, on to my question/situation: I just picked up a 2wd, non e-locked, V6 2000 Taco axle. I got this axle due to the fact that it was cheap($150), better clearance than a 44, stroner too, and was the correct BP. I still need to change the gears to 4.56s, weld the correct mounts on, and finally, add a locker.
Since my goal is to keep this build on the cheap and cheap, I do not want to go with an ARB or Detroit. I have been searching here, and other sites, and have found that LockRights and Aussies are available for the axle mentioned above.
So, are my findings correct? Do the various places sell a LR or Aussie for a 2wd, V6, non e-locked 2000 Taco axle?
Thanks for the help.
Fergie
(Toyota convert)
Old Dec 6, 2004 | 02:49 PM
gumbo's Avatar
If it is the same 8.4 ring gear as the 4wd Tacos then yes lockright or Aussie should work.
Old Dec 6, 2004 | 02:51 PM
Fergie's Avatar
Same as a 4x4, non e-locked Taco.
Fergie
Old Dec 6, 2004 | 03:14 PM
gumbo's Avatar
Thats it. Either locker will work.
Old Dec 6, 2004 | 10:27 PM
jimbo74's Avatar
make sure you are getting the right locker though... if it was e-lock equipped, or trd, then it has the toyta 8" axle and not the 8.4" that you have...
Old Dec 8, 2004 | 12:36 PM
Pretacopower's Avatar
So this axle came out of a Prerunner then, right?
If so and if you decide to go with a Lockrite, you need part #1615. I put one in the rear of my 2wd (Prerunner) Taco last summer.
Old Dec 8, 2004 | 04:52 PM
Fergie's Avatar
No, this came out of a non prerunner, non e-locked 2wd V6. Just a plane jane Taco.
It doesnt much matter though. As long as the locker is for a non e-locked version, I'll be fine. I'll check on the PN though, so thank you.
Fergie
DeathCougar
Apr 1, 2018 11:29 PM
Ryall
Sep 2, 2015 06:48 AM
Crgrey42
Aug 10, 2015 04:23 AM
A2theK
Jul 12, 2015 10:46 AM
