Lifted torsion bar question
Old Sep 20, 2009 | 12:38 AM
aerocorey's Avatar
I just bought a truck with a 4" bracket lift. The driver side front was an inch lower than the passenger side. I adjusted the torsion bars to level it out. The trouble is I had to adjust the driver side as tight as it will go, there are no more threads to turn on the bolt. The passenger side is barely tight at all. That isn't with the arms cranked way up either. It's with the arms horizontal. I'm not bothered by that in itself, but I know that if the driver side drops again I can't do anything about it short of replacing the torsion bars. Are these probably my stock torsion bars or do bracket lifts come with new torsion bars? Do I need longer than stock torsion bars? This thing doesn't flex in the front AT ALL off road. I know they don't flex very well, but I'm talking NOTHING. If I don't NEED longer torsion bars with this lift I'll get some stock replacements. Maybe that'll straighten out the uneven adjustments and loosen up the ride a little. Yes, no?
Old Sep 20, 2009 | 06:07 AM
James Dean's Avatar
Sounds like someone didn't get them back in the splines the same on the cam arm. Or something else is wrong with the lift.
Old Sep 20, 2009 | 07:02 AM
BigBluePile's Avatar
You can't get longer torsion bars, just thicker diameter. IIRC, those bars only go into the cam arm one way... If they're that outta whack, then it might not be a bad idea to replace them.
Old Sep 20, 2009 | 11:01 AM
aerocorey's Avatar
Thanks. Looks like a set of stock replacements are in my future.
88sasturbotoy
Jan 30, 2026 01:57 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
DrZero
18
Jul 24, 2015 11:31 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
