fabtech/superlift/skyjacker/or other which lift guys???
Old Dec 9, 2005 | 04:51 PM
fruitstripe's Avatar
i am going to retain my IFS. but i am looking on line for a lift for my 86 pick up extended cab. Has anyone had good luck and good FLEX with some of the kits out there. i have 31 inch super swampers on it right now but need some more ground clearance and flex. the 31s will be staying on till i sell them or they wear out. if anyone has some good or bad openions i would love to hear it.
thanks
jon
Old Dec 9, 2005 | 06:23 PM
deathrunner's Avatar
If you have the money:
www.jdfabrictaion.com
Old Dec 9, 2005 | 06:36 PM
link didn't work man also looking at the procomp with maybe the coilovers
Old Dec 9, 2005 | 06:40 PM
jethro's Avatar
After some serious fabrication I got you a link that'll work.
www.jdfabrication.com
Old Dec 9, 2005 | 06:43 PM
holy crap that is some crazy travel but wow what a price tag
Old Dec 9, 2005 | 07:49 PM
tc's Avatar
tc
Fabtech doesn't have a 4WD lift for this year range Toyota - only 2WD. I had one of their older lifts, and it was great!
If it's 2WD and you're looking at the Fabtech spindles, note that you might need new wheels to clear the backspacing...
Old Dec 10, 2005 | 04:23 AM
no its 4wd i was just listing some brands i meant to put procomp down
Old Dec 10, 2005 | 08:56 AM
How can you run coilover's with the procomp. I must have missed something.
superlift, trailmaster, procomp, black diamond, bds are all basically the same. Of those Superlift is the best (Strength)
Rancho made kit, but it is kinda funky.
Downey took Rancho's kit and made it funkier.
Total Chaos started the long travel arms as far as I can tell
Jd fabrication and ESB fabrication improved on the designs
Then there is the ball joint spacer, simple, cheap, and effective.
Then there is the Solid Axle Swap
I think that is all of the options.
Old Dec 10, 2005 | 10:51 AM
well i kinda miss spoke cause the procomp shocks are coil overs but works with there standard lift
Old Dec 11, 2005 | 04:33 PM
which big name kit do you think will give me the best travel
Old Dec 12, 2005 | 07:51 PM
elripster's Avatar
Ball joint spacers or a high end long travel kit. Here's the thing, all the big name kits (excluding again the long travel Total Chaos, etc...) don't get you more travel unless you modify them. This is by no means hard to do, just want you to understand you'll need to do some fabrication to get more travel. Don't get the Pro comp Stage II, it is the hardest to modify for more travel.
You can add bj spacers to the Superlift type kits too.
The thing you want to look for are the kits with the one piece drop brackets. The Superlift and Black Diamond are two. Just looking at them, I pick the Black Diamond. It looks like it would be easy to add an extra skid plate to the BDS too.
Frank
Old Dec 12, 2005 | 09:21 PM
I think stock travel is like 7" (Someone confirm or correct this)
Any of the barcket kits (superlift, black diamond, bds, trailmaster, procomp) will get that same 7" of travel
BJ spacers will kick it up to 8.5" of travel (1.5" more, I believe)
A long travel kit (chaos, ESB, JD fab) will get you 12" with stock cv's
http://photobucket.com/albums/v373/D...t=IMG_4061.jpg
Protrux is developing upper arms for these trucks. I have already seen one set installed on a t-100 and it pulled 9.5-10" of travel. Kind of a cool intermediate step.
www.protrux.net
I would get BJ spacers and wheel those, you'll probably like em. If not, they would be easy to sell again if you decide to upgrade. They're great products.
Old Dec 12, 2005 | 09:31 PM
Beast's Avatar
SAS is the best
ifs is a waste of time
Old Dec 13, 2005 | 07:23 AM
rockota's Avatar
I used to believe that as well, until I installed the Superlift kit on a 94 4Runner. Unlike most IFS kits, the compression bumpstop extensions do NOT match the lift; they are 1" less drop. Where TrailMaster and others match their 4" bracket lifts w/ 4" bumpstop drops, the SL kit has 4 and 4.5" bracket drops (1/2 longer on the rear bracket - not sure why), but the bumpstop drops are only 3 and 3.5".
When I installed the kit, I also installed Rockstompers IFS travel kit (1/4" balljoint spacer and 3" drop bumpstops. I was surprised to see that the SL bumpstop drops were almost identical to the Rockstomper drops...
So, in theory, the SL kit should give a good amount more travel than stock.
Old Dec 13, 2005 | 08:15 PM
Good to know rockota.
I'd be curious to get some meausrements off of that setup (with and without bj spacers)
also, am I right abotu the stock travel numbers?
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
akaphilly
Jul 9, 2015 02:18 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
timmJ
Jul 7, 2015 02:01 PM
