E-Locker for 97 4runner
Old Mar 19, 2006 | 07:50 AM
HardRunning97's Avatar
Looking to put a electronic locker for my rear diff in my 97 4runner sr5 and wasn't sure where to look or what to get. I hear some talk about some of the 96-02's coming with a locker for the rear diff and wanted to know if that was available aftermarket and also the TRD one for a tacoma... is that able to be installed in the 4runner??
Old Mar 19, 2006 | 08:14 AM
arjan's Avatar
Use the search, lots of info around on Yotatech about elocker installs. I did mine, if you're close to BC, Canada then I know one for sale locally.
Old Mar 19, 2006 | 09:06 AM
byron4's Avatar
youll have to do some fab work to fit it in your rear housing or you'll have to pay someone to do a little cutting/welding. i cant remember who just did a swap on here but they had a third gen and i think they just swapped whole the whole axel for an axel with an e-locker already inside it from the factory. it is not an aftermarket add-on where you can just put it in, modification is required. here are some instructions: http://67.122.16.97/carterman/4runner/mods/locker/
Old Mar 19, 2006 | 09:12 AM
arjan's Avatar
I had my housing modified to have one put in, not a very big deal imo. Then there is the wiring option of using the original toyota setup, or wire it up with relays from scratch.
Old Mar 19, 2006 | 08:01 PM
Will it be a straight swap to switch out the whole rear axle or better luck doing the mods to the diff to fit the locker??
Old Mar 19, 2006 | 08:05 PM
Bob_98SR5's Avatar
hard,
you really need to read a few threads on the topic so you can make up your own mind as to which route is better for you. no one knows your capability as a mechanic/fabricator or your $$$ situation.
search:
- elocker mod
- elocker retrofit
bob
Old Mar 20, 2006 | 12:29 PM
tc's Avatar
tc
I was really considering elocker. Added it up and ARB was about the same price if you want onboard air compared to a USED elocker and a Trutrac. Some really great deals out there for ARB's - basically get the compressor for free.
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
AaronM
Jul 8, 2015 07:15 PM
