Crawl Box Questions
Old Oct 16, 2008 | 11:34 AM
Johannes's Avatar
Crawl Box Questions
For those of you looking in the 1st Gen 4Runners threads, you'll see I'm looking into getting a 4Runner with a couple of modifications, but the one thing I'm thinking about adding is a crawl box, only because I've heard of the cool things you can do with one.
But, I had a couple of questions. First, while I've heard what they can do, I have no idea how they actually work. So, can they be disengaged so that road driving is possible, or is it a fixed system? Where exactly does it get mounted? Considering I'm not looking for much larger wheels (that require birfield eliminators), would I even need the box?
Old Oct 16, 2008 | 11:44 AM
swapped89's Avatar
The crawl box can be engaged and disengaged just like your regular 4wd. its like being able to put your truck in 4 lo, and then you have another stick to put it in double 4 lo.. Or you could just put lower gears in your stock transfer case box. it will make your 4 lo go super slow. cheaper than getting dual cases.
Go to marlincrawler.com or trail-gear.com they have some stuff you can read to better educate yourself on transfer cases and crawl boxes.
Old Oct 16, 2008 | 12:06 PM
tc's Avatar
tc
www.marlincrawler.com under Products-Transfer
Old Oct 16, 2008 | 02:25 PM
Johannes's Avatar
Thanks!
Old Oct 16, 2008 | 05:36 PM
bigarms23's Avatar
when i drive on the street with duals i have the front box in low and the rear in normal 2wd
delmert
Sep 30, 2015 04:34 PM
B1gR3d
Aug 1, 2015 10:10 PM
rushw
Jul 18, 2015 01:46 PM
crashburnoveride
Jul 10, 2015 06:39 AM
akaphilly
Jul 9, 2015 02:34 PM
