arb locker question
Old Feb 15, 2009 | 04:34 PM
hauckster's Avatar
arb locker question
so I'm looking at buying a new mud truck. its a 91 truck newer paint, no rust frame is mint, front end upgraded to all spicer components ( ball joints, tie-rod ends, bushings, etc), 4 inch procomp stage 3 lift with all upgrades available and airbag helpers, 3 inch body lift (guessing performance accessories), 212,000 km on vehicle 42,000 on motor, 3 inch fender flairs, 35x12.50 BFG mudders on eagle alloy rims, re-geared with 5.29s.
apparently this truck has an ARB air locker in the rear diff but needs a compressor and its good to go. i know that the ARB's are fed air through an air line but i have never seen one in real life so i would have no idea where to look for the air supply line off the locker.
what i want to know is can i tell if there is an arb in the diff without having to drop the diff out of it?
a picture is worth a thousand words :hint hint:
thanks a bunch
Last edited by hauckster; Feb 15, 2009 at 04:35 PM. Reason: spelling not my strongest piont
Old Feb 15, 2009 | 04:37 PM
bigt's Avatar
yeah there is air fitting on the diff. its copper hardline in the diff...
waskillywabbit's Avatar
See the little red cap, under that is a brass fitting for where the ARB line connects. That is just an indication there is an ARB in there but no way to be 100% sure without pulling the diff.
Old Feb 15, 2009 | 04:54 PM
hauckster's Avatar
yeah i figured that that was the only way to know 100% but i was just looking for a way to check when i go look at it again this week
and its the same with the rear diff on the same side and everything too?
Old Feb 15, 2009 | 05:12 PM
tc's Avatar
tc
Should be pretty close to there if not exactly in the same spot.
Jun 1, 2021 01:51 PM
Ironmike4x4
Feb 3, 2016 11:13 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
coffey50
Jul 28, 2015 10:55 AM
A2theK
Jul 12, 2015 10:46 AM
