ARB air leak
Old Jan 6, 2007 | 05:13 PM
tc's Avatar
tc
ARB air leak
One of the blue lines apparently got too close to the exhaust (while Molly was driving :rolleyes: ) and melted through. No biggie - my question is though, the compressor never reaches pressure and shuts off. But if the solenoid is closed, the broken line shouldn't matter, right? Do I have a bad solenoid too?
Old Jan 6, 2007 | 07:21 PM
AH64ID's Avatar
You could have a burned up valve on the pump.. ARB pump? Mine went out and all it does is run and run.....
Take the solenoid out and plug the hole... if it fixes it there is your problem.. if it doesnt.... i would send the pump to ARB for fixin...
Old Jan 6, 2007 | 07:28 PM
DeathCougar's Avatar
if the locker is on, then the compressor will continue to run until it reaches "pressure"
Old Jan 6, 2007 | 07:29 PM
Tofer's Avatar
Sponsor
i know neil (gapguy) had a problem wiht his ARB leaking in is old 4runner
Old Jan 6, 2007 | 09:00 PM
tc's Avatar
tc
Runs and runs with the locker OFF.
If the ARB compressor is gone, I'm gonna have to research higher flow options...
Old Jan 7, 2007 | 04:30 AM
AH64ID's Avatar
Not a bad plan, had I known the other options I never would have bought my arb in the first place... if all you do is lockers it okay, but I do tires too....
I would consider sending it to ARB first, might get fixed for free... they have reapaired mine twice at no cost...
Old Jan 7, 2007 | 11:59 AM
tc's Avatar
tc
Well, if it's FREE.... LOL
Old Jan 7, 2007 | 12:04 PM
waskillywabbit's Avatar
Fix the blue line first...then see what happens. ARB has a new "mini" compressor too and there are other options.
I prefer a 100% duty cycle compressor and an air tank to the little ARB compressors...I can fill up the tank once in the morning and wheel all day and the compressor might come on once...and that is cycling the lockers quite a bit.
Compressors: http://www.wabfab.org/products/compr...ompressors.htm
ARBs and leaks are all about the competence of the installer, unless you break an axle shaft or something and damage the inner workings of the ARB...seen that happen on a buddies' Heep at work...busted something inside the ARB and had to send it back, but they did fix it for free.
Old Jan 9, 2007 | 07:20 PM
Sporticus's Avatar
So, can you run an ARB locker(s) off of a Viair 400c with no auxilliary tank? I was thinking of just making a mult-port manifold (as opposed to a tank) and connecting a pressure switch, both locker lines, and a quick disconnect to those ports.
Keep in mind, the QD would only be for filling tires, and I would never be using the compressor to do both jobs at once (run locker and fill tires).
Is this doable? Sorry if this is the wrong place to post this, I don't mean to thread-jack.
Old Jan 9, 2007 | 07:30 PM
You will want to run a tank...2.5 gallon tank makes a big difference...and I can run whatever I want at the same time.
Old Jan 9, 2007 | 07:33 PM
tc's Avatar
tc
OK, I'm a dumbass. My new bumper is fitted for air storage:
The "outlet" fitting on top got snow packed in it the other day and must have gotten stuck in the "open" position, and leaked enough that I didn't really hear it. I put some tape over the top to keep any snow out, and that allowed me to hear it leaking. Fixed the coupler, and the compressor shuts off as it should now.
Sporticus:
You can use any compressor (or even CO2) to run the ARB's, but you have to be VERY careful about the pressure. Don't exceed 90psi or you risk blowing out the seals in the diff. The tank is still a REALLY good idea. Here's a compressor that looks VERY interesting for our applications:
http://cgi.ebay.com/ebaymotors/PUMA-...QQcmdZViewItem
3CFM could probably run air tools for short periods with the tank...
Old Jan 9, 2007 | 07:51 PM
Sporticus's Avatar
^ Thanks, guys.
I already have the Viair. Just trying to build around it and do it correctly.
So, TC, you are saying I should use a regulator on the ARB line in conjunction with an 85/105psi pressure switch (I alrady have the PS, too) on the tank b/c 105psi will be too much for the seals?
Is there a fixed (non-adjustable) in-line regulator for ARB use (85-90psi)? Something nice and small?
Old Jan 10, 2007 | 03:49 AM
AH64ID's Avatar
The ARB psi switches are 70/100. So you can exceed 90psi, I just wouldnt go above 100ish.. 105 is probally safe.
Old Jan 10, 2007 | 10:32 AM
tc's Avatar
tc
I thought they were like 70/85 ... but could be wrong. Personally, I don't think it's worth risking it. You could call ARB - bet they could tell you exactly. Supposedly they have good customer service - never needed it myself though.
Old Jan 10, 2007 | 10:37 AM
Flygtenstein's Avatar
Tim was the best guy at ARB, he left.
I am pretty decent.
The compressor turns on at 75 PSI or lower and off at 100 when I was investigating.
This is why just blasting most shop air into the locker to pressure test is really a great idea.
Good luck.
Old Jan 10, 2007 | 10:39 AM
Talking
I have a 105 psi pressure switch on my air tank that feeds my manifold for my ARBs...no problems.
ARB specs: http://www.arbusa.com/alac/alsp/3-01.pdf
Old Jan 10, 2007 | 10:42 AM
tc's Avatar
tc
Guess I was mistaken - thanks for the clarification guys. (My experience was based on someone using CO2, and not being even close - like 200psi or something stupid)
Old Jan 10, 2007 | 10:53 AM
I think that there is a safety margin built in.
If 100 is good, 150 is not half again as good.
The ARB compressor is made for tires. You want more air, get CO2.
Many fine ARB's have given their lives airing up tires more than 28's.
Old Jan 10, 2007 | 10:55 AM
Old Jan 10, 2007 | 12:36 PM
Robinhood150's Avatar
My friend runs his ARBs with no tank and he seems to like it. The compressor runs for only a couple seconds once in a while.
