4wd problem/tranny swap/t-case swap
Old Apr 1, 2005 | 10:24 AM
squishy321's Avatar
I have a 93 4runner 5 speed manual with ADD, you probably know what im gonna ask next but hold on a sec. I just took out the g58 and tcase and put in a w56b and tcase ( anyone wanting to know something bout this swap just ask) Now I also changed the cv joint because it was broken. Upon putting the new trans back in i noticed that there are a lot of wires that arent hooked up, only one i hooked up was the o2 sensor. When i took the truck out for a spin there wasnt any 4wd, is this because wires arent hooked up to the tranny or tcase, can i hook them up to this older none add transmission, or is it just some simple issue with differential oil or vacum lines. I did a seach but every single piece of advice kind of applies to my situation so i was hoping to narrow it down
Old Apr 1, 2005 | 10:36 AM
aferg's Avatar
I had this problem too… My solution was to get rid of the ADD, just lock the front diff and add manual hubs. http://www.4x4wire.com/toyota/tech/add/index.htm?
Not really what your asking but just another way to go.
Hope this helps.
Old Apr 1, 2005 | 10:41 AM
Robinhood150's Avatar
Although this is a "repair" it has a lot to do with the 4wd so I'm moving this to the off road section instead of the maintenance section.
Old Dec 5, 2009 | 03:34 PM
kechikan's Avatar
g58 swap
Hi there.
I am thinking about swaping a g58
Does fit totally the w56?
mskalmus
May 28, 2017 07:51 AM
adammtb
Jul 27, 2015 11:57 AM
ripp96
Jul 25, 2015 02:32 PM
TokyoD23
Jul 12, 2015 06:01 AM
Coreyr384
Jul 10, 2015 11:13 AM
