255/85/16 BFG's?
Old Oct 4, 2007 | 01:45 PM
elbandito's Avatar
255/85/16 BFG's?
I have an 05 4Runner SR5, V6, OME lift. Do you think I could fit 255/85/16 BFG MT's w/o spacers w/o rubbing? I'm thinking about going taller/skinnier rather than wider. It seems that most of the rubbing problems are caused by the tire width rather than height.
Old Oct 4, 2007 | 02:00 PM
Diesel_Freak's Avatar
I'm pretty sure tha tif you're running stock rims or rims with stock back spacing you could run them with no lift. Great tire size BTW that's what I'm buying next...
Old Oct 4, 2007 | 02:38 PM
tc's Avatar
tc
That is a fact.
Old Oct 5, 2007 | 08:23 PM
Yep... Toyotas (espescialy older ones) had no problems with fender clearance untill you get into those silly wide tires...
Old Oct 7, 2007 | 07:23 AM
elbandito's Avatar
Thanks for the input. Do you think that the 255/75/17's would work on my factory 17" rims? My concern is whether they will rub or not at full flex/full turn. I think with the OME lift, it should be alright, but I just wanted to check first.
nvwiggins
13
Jun 16, 2016 03:05 PM
muddpigg
Nov 2, 2015 05:36 AM
87SR5justin
Sep 29, 2015 02:45 PM
94toyy
12
Sep 14, 2015 06:18 AM
AkitaDog
Sep 3, 2015 09:01 PM
