$17 t-case armor for 3rd gen
Old Mar 15, 2004 | 05:19 AM
transalper's Avatar
I bought a $17 piece of 3/16" steel plate last week and mounted it up yesterday. If necessary I may add some reinforcemnt, but I think 3/16" should hold up just fine. We'll see . . .
Old Mar 15, 2004 | 05:22 AM
jacksonpt's Avatar
Senior Member
Good deal... just watch those bolts don't round off as you drag 'em across rocks. Could make getting that skid off a bit of a chore.
Old Mar 15, 2004 | 05:30 AM
transalper's Avatar
Yup. Nothing a vise-grip can't handle though.
Old Mar 15, 2004 | 09:13 AM
Ranski's Avatar
Thanks for putting the dimensions in your photo. Nice job!
Old Mar 15, 2004 | 09:20 AM
Hyperlite's Avatar
Torch it off or drill it out, no biggy at all. Great idea unfortunently my metal is a couple of inches short, guess i need to take a trip to the steel shop
Old Mar 15, 2004 | 09:44 AM
85runner's Avatar
Nice idea!!
Old Mar 15, 2004 | 10:48 AM
shazaam's Avatar
Lets see $300 TC plate .... Or $17 transalper plate?
Thanks for the idea man.
Quick question though, are the mounting points already there? So basically I would just drill the holes in the metal sheet, and screw them in, right?
When I put mine up, I'll engrave Transalper into it
Old Mar 15, 2004 | 11:35 AM
transalper's Avatar
Thanks man, but it's just a plate.
The mounting points use existing holes in the cross members, so all you have to do is drill four holes in the plate and bolt 'er up.
I'll be testing it out in Moab in two weeks, so we see how it holds up without any reinforcement.
Old Mar 15, 2004 | 11:42 AM
Ranski's Avatar
What size bolts did you buy?
Old Mar 15, 2004 | 11:51 AM
transalper's Avatar
I used 3" long 3/8" bolts for the front crossmember and 2.5" long 3/8" bolts for the rear crossmember. I plan to swap these out for metric grade 8 bolts eventually, but I had a bunch of 3/8" bolts lying around.
Old Mar 15, 2004 | 03:00 PM
ravencr's Avatar
Sweet mod, man! I'm planning to do something similar, but will be reinforced on the edges with DOM tubing, and then two cross tubes on either side of the transfer case from left to right, to really guard that puppy. I've already bent up my balancer and light weight stock guard.
Chris
Old Mar 15, 2004 | 04:34 PM
transalper's Avatar
Make sure you post pics of your finished t-case armor.
If I decide to reinforce it, I'll probably notch out the four courners and have the sides bent up a little bit.
Old Mar 15, 2004 | 04:46 PM
shazaam's Avatar
Originally Posted by ravencr
Sweet mod, man! I'm planning to do something similar, but will be reinforced on the edges with DOM tubing, Chris
Whats DOM tubing?
Old Mar 15, 2004 | 04:48 PM
Dr. Zhivago's Avatar
Away
DOM = Drawn Over Mandrel
Peace.
G
Old Mar 15, 2004 | 04:50 PM
shazaam's Avatar
Peace.
G
and for us non-engineer types that translates into?
Old Mar 15, 2004 | 04:51 PM
ravencr's Avatar
I'll do it!
Chris
Old Mar 15, 2004 | 04:56 PM
Away
DOM (Drawn Over Mandrel) Pipe is made from strip bar stock that is rolled, welded, and pulled through circular dies. The result is a straight, stiff, economical pipe. It's beefy and strong.
G
Old Mar 15, 2004 | 04:57 PM
Bob_98SR5's Avatar
jay,
ah yes, one of those "now why didn't i think of that?!!?!"
ingenuity at its best. great mod! by the way, how much does that nice piece o' metal weigh? approximate is good too.
and if i do this mod, it'll be branded as the "transalper".
bob
Old Mar 15, 2004 | 04:59 PM
shazaam's Avatar
G
Ok thanks for the clarification. This doesn't sound like something I'll be able to do on my own. I'll just have to stick with the plain plate
Away
Originally Posted by Bob_98SR5
jay,
bob
What he said. I meant to say something about the mod, but spaced because I was answering someone's question.
Good job, dude!
G
