99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
What to look for in a T100?
Old May 30, 2005 | 07:45 PM
Aggie03's Avatar
I'm looking at a 97 T100 4x4 and I'm wondering what to look for. It has @ 108,000 miles on it and the owner has not changed the timing chain so I know that needs to be done. What else??? Any recalls or things that wear out that need to be replaced?
What does the timing and water pump replacement cost???
Thanks for your help.
Brad
Old May 31, 2005 | 12:50 PM
Flannelman's Avatar
First the Truck if it has a 3.4 is a belt not a chain. Second I can't remeber any recall other than the Headgasket on the older 95s. Mostly you'll want to look for leaks and things of that nature. It also wouldn't be a bad idea to have it looked at by an independent mechanic. I'd also recommend if you haven't done it run a carfax on it to make sure it hasn't been in an accident. I can't think of anything else right now I'll post back if I think of anything else.
Old Jun 5, 2005 | 09:58 PM
Aggie03's Avatar
Well, I looked at a 97 today with 140,000 miles on it. The guy said that he bought it with 82,000 on it and he hasn't replaced the timing belt on it since he has had it. Should I be concerned about that?
He wants $7500 for the truck, do you think this is a good price?
the body has some dings and scratches also the muffler is full of holes. He did say something about getting new struts for the front and new brake roters.
What do y'all think???
thanks
Brad
Old Jun 8, 2005 | 07:57 PM
bigbadktm's Avatar
sounds like the guy doesnt care about the truck and that says a lot. i would pass on that one. most trucks recommend the timing belt be changed at 60k, yet the 3.4 is at 90k. still way over due.
Old Jun 9, 2005 | 08:39 AM
Flannelman's Avatar
Same here I'd pass on it there are guys out there that baby there trucks and those are the ones you really want. Though if you can find one thats been taken care of with normal maintance it should do nicely. Also I can look a bit online if I get a chance. What kind of miles, Cab size, trans, 2wd/4wd, and the other options are you looking for as that will help us give you a better price check for the trucks.
stanz
Oct 30, 2015 10:33 AM
toyhaulert100
Sep 24, 2015 07:55 PM
tallsasquatch
Sep 20, 2015 02:48 PM
mat
Sep 17, 2015 11:18 PM
Tcsdef
Sep 7, 2015 11:17 PM
