99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Problems with the ABS & Traction Control on Sequoia
Old Aug 30, 2002 | 03:15 PM
Angry Problems with the ABS & Traction Control on Sequoia
I have a 2002 Sequoia 2wd Limited that has had interminent problems where the ABS/Trac Control lights will come on and not go off until the vehichle has been turned off. Additionally, we have had a problem where the traction control will activate when pulling away from a stop. The road is perfectly dry but the system decelerates the vehicle for several seconds.
Has anyone else seen similar problems?
Thanks,
Steven Dunker
Old Sep 4, 2002 | 03:55 PM
Darren's Avatar
How long are you giving the lights to shut off. When off-roading and the Trac system comes on due to slippage, it can stay on for upwards of 20 seconds or so which is wierd. If your talking about minutes, I would have it looked at as I doubt that is normal.
As for decelerating when pulling out, are you talking about turning onto a street or going straight. On my '02 Runner, I only have this happen when turning onto a street because there's 2 pieces of gravel under one of the tires. :mad:
That aspect of my rig is the only thing I don't like about it. It's absolutely useless for on-road use. On second thought, mall moms or newly licensed drivers might need it! I can't wait to drive it for a full winter! Might have to lock the center diff a few times to prevent this.
Old Sep 7, 2002 | 04:38 AM
Actually the lights stay on until the vehicle is turned off and that is what concerns me. I have had it in to Toyota 6 times and they have replaced various parts, this last time they attributed it to a loose wire. Personally, I think it is hard to believe they missed the wire 5 other times, but who knows. We will wait and see.
As for the slippage I am pulling away from a stop sign going straight on a dry road with no gravel, water, ice, snow, oil, etc . It appears the traction contol thinks the vehicle is slipping but really is not. They haven't been able to track that one down.
Steve
Old Sep 7, 2002 | 09:24 AM
Darren's Avatar
Hmmm. I definitely think you're right about a loose wire or something on the lights, but 6 times? Wow. They might need to check under the hood next time! Good luck with that. I'd be frustrated too.
I've never had a problem with the system leaving from a stop going straight. It's tough to diagnose that one and I don't know how you'd go about seeing if that's normal or not. I guess test drive another Sequoia.
You might want to post this on the 4Runner/SUV forum as the system is the same as the 4Runner's. Someone there with an '01/'02 might have some other suggestions. I just happened to come over here a few days ago and saw your post. I don't think too many wander over here.
Or, try over at: http://66.216.68.23/cgi-bin/ultimate...ubb=forum;f=13
djpg2000
Nov 11, 2020 04:56 AM
rushw
Jul 18, 2015 01:46 PM
1994toyota
Jul 17, 2015 03:03 AM
voiddweller
Jul 15, 2015 03:56 PM
Suprarossa
Jul 6, 2015 05:21 AM
