99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old Mar 31, 2016, 02:04 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Interior Guides
Print Wikipost
IAT Sensor Trouble code p0113
Old Jun 24, 2014 | 07:49 AM
Catamount's Avatar
New to me 2004 V8 4.7 with KN cold air intake also new to me. The check engine light came on and diagnostic trouble code suggests the IAT sensor has bad connections, has failed, has open return circuit or is shorted to voltage. I assume the IAT is the module attached on top of air intake also if it had a GF chip installed it also would be right there on the wiring harness. If I'm in the right place I don't see a GF that might foul things nor any obvious problem. The air filter is all black so seems it needs cleaning. I've searched on line and so far can't find a replacement.
Any advice on fixing my situation.
Old Jun 24, 2014 | 08:54 AM
Catamount's Avatar
Did some more research and found I'm in the right place and the IAT sensor (intake air temperature) is part of the MAF sensor (mass air flow) so found replacement MAF sensor for about 80 bucks if I need it. First I want to try a MAFs spray cleaner and clean the air filter. Then if need be will ohm test the sensor with a hair dryer.
Can anyone tell me the ohms cold then hot for a working sensor and any suggestion for a good cleaner to try. I already have the KN cleaning kit for Filter.
Old Jul 5, 2014 | 07:39 AM
kuzbro's Avatar
Hopefully you have fixed the problem by now, but I'm throwing in this information anyway, and it's for my 2010 5.7, hope it helps.
3UR-FBE ENGINE CONTROL SYSTEM: MASS AIR FLOW METER: INSPECTION
  1. INSPECT MASS AIR FLOW METER
(a) Check the output voltage.
(1) Apply battery voltage across terminals 1 (+B) and 2 (E2G).
NOTICE:
While using the battery during inspection, do not bring the positive and negative tester probes too close to each other as a short circuit may occur.
(2) Using a voltmeter, connect the positive (+) tester probe to terminal 3 (VG), and negative (-) tester probe to terminal 2 (E2G). (3) Blow air into the MAF meter, and check that the voltage fluctuates. If the result is not as specified, replace the MAF meter.
(b) Perform a visual check for any foreign matter on the platinum hot wire (heater) of the mass air flow meter shown in the illustration. OK:
There is no foreign material.
(c) If the result is not as specified, replace the mass air flow meter.
(d) Check the IAT sensor.
(1) Measure the resistance according to the value(s) in the table below. Standard Resistance:
(2) If the result is not as specified, replace the MAF meter.
Old Jul 7, 2014 | 05:22 PM
Catamount's Avatar
Thanx Kuzbro this good info if I had to go that far. Luck has it I got some MAFM electronic cleaner and a cleaning kit for the CAC. The air filter in particular was very dirty. A good cleaning of both fixed me up.
Blamalam
Mar 12, 2022 07:34 AM
raptor510
Feb 17, 2017 07:11 AM
raptor510
Aug 19, 2015 02:15 PM
nonstop
Jul 24, 2015 06:29 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
