99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old Mar 21, 2016, 12:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Brake Guides
Print Wikipost
HELP!! Front end vibration....unknown source
Old Jun 20, 2010 | 11:25 AM
Rocker Jockey's Avatar
I have a 2000 Tundra SR5, I have put the Tuff Country 5" lift on with Fabtech adjustable coilovers that are up about 2" more so I am sitting pretty at about 6 1/2 to 7...... Here is my question.... I have just recently had new CV axles replaced at Les Schwab and new 315/70/17 tires on. After the axles were replaced I notice an annoying vibration in my front end while around the speeds of 65 to 75 mph. I took it back and they replaced the axles again with brand new ones and even had the tires replaced with a completely different brand and rebalanced umpteen times and it has not fixed the problem.... everything is solid, no movement in the sway bar or control arms... would it be something to do with bad wheel bearings or something? It is definitely speed related cause it stops under 65 and doesnt stop when I throw it in neutral while at vibration speed. Any ideas or similar problems? Any suggestions or help would be greatly appreciated!!!! Thanks!!!
Old Jun 22, 2010 | 11:45 AM
maxzoller's Avatar
It may be your front brake rotors. if you don't use the parking brake the rear brakes don't calibrate and the front rotors warp pretty bad.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
Daneums
Aug 20, 2015 05:36 AM
cyclist231
Jul 7, 2015 12:56 PM
