99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
heat control issue
Old Jun 28, 2022 | 05:41 AM
64fabius's Avatar
heat control issue
I'm Fabio From Italy and I've got a 1999 UZJ 100.
Since I started attending the forum, I have always read your comments and I really appreciate your technical answers regarding the maintenance of the LC. So I would be very happy if you could help me in solving a problem that I have in my car for some time. Since I had bought my LC about 4 years ago, the front heat ventilation never worked correctly while the rear one operated well. So, I and my mechanic replaced the engine radiator, the thermostat and T pipes. We washed the entire cooling system and used a water solution with a rust remover as "CLR" to wash and flush the front cabin heater core.
After that, front hot air flow restarted for only a few months. In fact, now the problem has returned as before. The heat ventilation does not come out from the front vents even if the heat knob is set to the max. Even, when the temperature knob reaches maximum value in manual setting, the air flow decreased in comparison when it is set to a lower temperature. All tests were carried out excluding AUTO but using only MANUAL mode.
Now I'm going to reflush front heater core using a product like CLR but in this occasion I'd want to leave it inside the core for a few hours before flushing it with fresh water.
What do you think about a problem on blend doors actuator or in a clogged heater core?
In your opionion, is there anything else to do?
Thanks a lot for your attention and helping me!
Bye
Fabio
Old Jun 28, 2022 | 08:01 PM
Discombobulated's Avatar
I would firstly verify the blend doors, while my truck is way different I have worked on a couple newer vehicles where the blend doors and vent selection is messed up one way or another and it just makes everything heat and cool related really weird, but I don’t know why it would have worked for a few then stopped working?
obviously I am not familiar with your model or year but mine is cables yours may be vacuum?
Either way I would pop the glove out and get the under dash removed and start poking around, that would be the cheapest option to start
I’m sure others that actually own an LC will chime in and might have other suggestions!!!!
I might also add, when my old Subaru was clogged from the previous owner shoving a bunch of stop leak crap in it, I did the same with CLR and you can tell if it’s clogged, I hooked up a hose on the inlet and gave it hell, the biggest longest tube of grey black crap came out and it flowed from there, Kept flushing until it was clear, now could it be possible that your core was clogged so bad that you kinda cleared it and it worked for a minute and then it clogged back up, sure but again that’s not a difficult thing to do again if you run out of options.
J100280
Nov 8, 2013 12:41 PM
higherelevation
Jan 8, 2013 10:20 AM
4sknrnnr
10
Feb 23, 2011 01:53 PM
MTL_4runner
79
Nov 7, 2007 06:26 AM
j_rod
Feb 8, 2006 03:55 AM
