99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
front diff location!
Old Mar 29, 2010 | 07:26 PM
Cal01's Avatar
where is the front diff plug?
Old Mar 30, 2010 | 01:42 PM
jim65wagon's Avatar
Of course, mines a Tundra but I'm fairly certain the diff is similar, if not the exact same.
The drain is low on the drivers side
The fill is high on the drivers side, next to the large bracket and tucked up behind the skidplate far enough I have to remove said plate to refill the darned thing.
Oh yeah, a little word of advice...remove the fill plug first; then remove the drain plug. Just in case the fill plug is frozen, stripped or otherwise can't be removed. Saves you from running around in someone elses ride while yours sits in the drive with no diff fluid in it!
Old Mar 30, 2010 | 01:43 PM
Elton's Avatar
haha have fun with those stupid allen head bolts mines ruined
Old Mar 30, 2010 | 01:54 PM
toyota4x4907's Avatar
Why the hell would they use Allen heads instead of just hex bolts?!
Old Mar 30, 2010 | 03:19 PM
Dr.Trevorkian's Avatar
as long as it's cleaner out and you can fully fit the proper size hex key in there it works fine, they are a lower profile (which doesn't matter in this location) and they allow a bigger hole I think.
Old Apr 29, 2010 | 01:18 PM
Bullet99's Avatar
10mm allen fits, soak hole in pen oil prior, then wiggle it in, make sure it seats at the bottom.
Old Apr 29, 2010 | 01:56 PM
strykersd's Avatar
I prefer the allen head plugs over the hex bolts myself. After you've dragged your diff on a few rocks it becomes difficult to remove the drain plug. Dragging my drain plug on a rock also managed to loosen the drain plug on two occasions. I have yet to have either of these problems with my low profile allen head plugs. YMMV
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
jaretstuff
Aug 4, 2015 02:08 PM
scottyg486
Jul 19, 2015 05:34 PM
TokyoD23
Jul 12, 2015 06:01 AM
