99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Changing O2 sensor, where is it?
Old Mar 15, 2005 | 01:42 PM
Have a 2000 Tundra V8 with 92K. O2 sensor ( past the converter ) needs replacing. Is there anything to changing it. Where is located? Anything need to be done after changing it? Priced OEM at AutoZone at $179. Thanks!
Old Mar 16, 2005 | 11:11 AM
tms2u's Avatar
There are 4 alltogether- 2 on each side. 1 before and 1 after the cats. Crawl under there and you'll see them in the exhaust. You might want to check to make sure they have a good connection as sometime some grit will get in there and corrode the contacts and give a false failure MIL
They can be tuff to get out, but if you soak them with PB Blaster or the like, they will come out. When putting the new ones in be careful not to cross thread the bung or you will be bummin.
Also Sparkplugs.com has a better price on them
Good luck!
Old Mar 16, 2005 | 12:12 PM
O2 Sensors
If the code says the rear, do you replace both?
Old Mar 17, 2005 | 08:29 AM
While you're in there messing around, pick up a set of SSA headers from ebay for $100 and slap those bad boys on.
Old Mar 17, 2005 | 09:49 AM
tms2u's Avatar
No it is either bank 1 or bank 2. Who read the code for you?
Old Mar 17, 2005 | 03:02 PM
Bank two
The code was read at AutoZone. It said that the bank 2 sensor was bad. I just noticed on several sites that they mentioned front right, front left, back right, back left. The guy at AutoZone said to change them both(rear). Thanks
Firefightersink15
Nov 23, 2015 10:32 PM
shredder4286
Oct 1, 2015 01:09 PM
accuracy
Sep 20, 2015 07:44 PM
larrys93pickup
Sep 17, 2015 07:05 PM
moparbay
Sep 3, 2015 12:48 PM
