99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
99 Landcruiser 4.7 - Location of Coolant Drain Plugs
Old Apr 8, 2014 | 01:57 PM
DocHolyrood's Avatar
I'm replacing the coolant in my landcruiser, which according to the owners manual takes 16.2 quarts, with rear heater. With the front and rear heaters on, I drained the radiator and engine block on driver's side but only got 12 quarts drained. I'm adding distilled water to flush it and was only able to refill with 12 quarts.
It took me a week to locate the engine block drain on the driver's side. Now I'm seeing reference that there is a 3rd drain, which is supposedly on the passenger's side of the engine block.
If there is a third drain and if so can someone help me locate it?
Old Apr 9, 2014 | 03:54 AM
I found the third drain on my 2UZ-FE motor. In addition to the radiator, there's a drain on each side toward the rear of the engine block. The passenger side is the most difficult to find because it's mostly hidden behind lines and such.
the1998sr5
15
Jul 14, 2020 08:35 PM
msane99
Jul 17, 2015 10:13 AM
ryerye13
Jul 14, 2015 08:27 AM
jetspeedz
Jul 13, 2015 09:32 PM
94whiterunner
Jul 12, 2015 07:15 PM
