99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
2000 Tundra starts, revs up, rough idle, then dies.
Old Jun 22, 2021 | 04:24 PM
ltgunkel's Avatar
I have a 2000 Tundra, 4.7l V8, 4x4, 220k miles. I can't track down the cause of this issue and I need some help.
When I turn the key, it starts right away. It revs up to about 1800-2000 rpm, then drops to a very low and very rough idle. It will die after 5-10 seconds. I can keep it running with the gas pedal and it seems to clear up and run smoothly when I get up to 2500-3000 rpm. When I try to hold it steady at 2000 rpm or less, it coughs and sputters and backfires through the intake.
This happened suddenly, not gradually over time. There are no check engine lights. So far, I've cleaned and inspected the throttle body, inspected the MAF (it's in pristine condition), cleaned the PCV valve, replaced all 8 spark plugs, and pulled the upstream O2 sensors to check if the cats were clogged (no change). I've also checked all of the vacuum lines for cracks, they all seat tightly and have no visible issues.
I've searched for quite a while but can't find a conclusive answer - what am I missing? What causes these issues?
Thanks
kawasakilewis
Mar 7, 2012 07:55 PM
Blueskyoklahoma
Oct 29, 2011 06:23 PM
joliver
Mar 7, 2011 02:48 PM
j-money$$$
Mar 31, 2009 09:19 PM
rivemxr6
Sep 28, 2006 12:46 PM
