99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
05 Sequoia - positive battery cable/fuse cables
Old Mar 1, 2017 | 07:56 AM
jpcolorado's Avatar
First post, please direct me if there is a thread on this topic.
My positive battery terminal is corroded and the connector to the fuse box cable snapped. I wanted to see if this is an opportunity for upgrading cables. I spoke with Toyota and they couldn't identify a cable that goes from the positive terminal to the fuse box. Does something like that exist? Or, would it be better to cut the cables and crimp a new attachment point to it for both the fuse cable and the positive battery cable? The dealer wanted $900 for the battery cable harness.
Just looking for some advise on the subject.
Thank you!
Old Jul 28, 2017 | 05:23 PM
75w90mantraN's Avatar
Pretty sure if you go over to any of the auto parts retailers, they can help with that for way less than $900. May want to check and see if that battery hold-down bracket is doing its job or letting your batt just bounce around, bend cables, and loosen connections.
