99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
04 Sequoia No Throttle Position Sensor?
Old Oct 7, 2013 | 11:46 AM
04Segotcha's Avatar
My 2004 Sequoia is showing all the signs of a bad throttle position sensor. One day throttle works great, the next will have mild to drastic hesitation (2" on the gas pedal gets you nothing). Occasionally at a stop light it will want to lurch forward for no reason. Idle is perfect. Napa and the Dealership parts dept show no TPS for this vehicle. Accelerator Pedal Position Sensor is all they list. RockAuto.com points to Cam Shaft and Crank Position Sensors. 2004 Tundra and the Lexus GX is the same. Check engine light is NOT on but has worked in the past flagging a bad O2 Sensor. Otherwise, well maintained and running great at 178k miles.
Old Oct 10, 2013 | 03:34 PM
04Segotcha's Avatar
If there is no Throttle Position Sensor what else is used in its place? Anybody know where to start?
Old Oct 10, 2013 | 03:44 PM
Kiroshu's Avatar
If I'm not mistaken the 2UZ-FE engine in your truck has the throttle position sensor "made" into the throttle body assembly and is not serviceable separately without replacing the throttle body assembly.
Old Oct 11, 2013 | 06:02 AM
04Segotcha's Avatar
Thank you very much! Really appreciate the help.
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
smiley52
Jul 11, 2015 05:16 AM
