Toyota FJ Cruiser Interior LED Lighting Conversion! Map / Dome / Cargo! See Pictures!
Old May 21, 2018 | 09:11 AM
Diode Dynamics's Avatar
FormerVendor
Lightbulb Toyota FJ Cruiser Interior LED Lighting Conversion! Map / Dome / Cargo! See Pictures!
Diode Dynamics carries a full line of LED replacements for your Toyota FJ Cruiser's dome lights, license plate lights, trunk light, turn signals, and more!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Your FJ Cruiser's dome, map, and cargo lights use an incandescent bulb from the factory, giving it a yellowish color. By replacing them with Diode Dynamics' LEDs, you can add a luxurious and modern look to your FJ Cruiser, with a cool white color, just like the lights on newer luxury vehicles. You can also increase the brightness with Diode Dynamics' HP6 or SMD12 Board model options, to improve the performance of your FJ's interior lighting.
The installation is 100% plug-and-play, just replace your FJ Cruiser's factory bulbs with Diode Dynamics LEDs!
Bulb Design:
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
SMF2: This bulb has a standard festoon base, with two forward-facing 5050-size Epistar SMDs. Direct replacement, plug and play.
HP6: Standard festoon base, with six 5050-size Epistar SMD chips arranged on a rectangular panel.
SMD12 Board: This is an LED panel, fitted with 12 5050-size Epistar SMD chips. Comes with spring-loaded festoon-style adapter for direct installation. Plug the adapter into the bulb socket, then just stick the board in place with the mounting adhesive pad. The board-and-adapter design allows for extremely high brightness compared to a simple bulb.
Brightness
SMF2: (16 lumens) Slightly lower brightness than OEM bulbs, but still provides the crisp, modern color of LED.
HP6: (130 lumens) Significantly higher brightness than OEM bulbs.
SMD12 Board: (118 lumens) Much brighter than OEM bulbs. These are bright!
Lumens: BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. Diode Dynamics engineers test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
Dome Light LED for 2007-2014 Toyota FJ Cruiser
Map Light LEDs for 2007-2014 Toyota FJ Cruiser (pair)
Cargo LED for 2007-2014 Toyota FJ Cruiser
Diode Dynamics products are backed by a 30-day satisfaction guarantee and a three-year limited warranty.
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
wiseguymmiv
Nov 13, 2015 08:56 AM
Fo_SheeZy
100
Nov 9, 2009 03:00 PM
Jason B
Oct 11, 2008 09:23 AM
fmg23
Dec 29, 2005 04:54 PM
