NOW AVAILABLE: Stage Series Reverse Light Kit for 2005-2021 Toyota Tacoma!
Old Nov 15, 2021 | 12:59 PM
Diode Dynamics's Avatar
FormerVendor
There's plenty of ways to add light behind your Tacoma, but the new Stage Series Reverse Light Kit stands out with innovations in both function and ease of use. This kit includes an integrated red running light, and plug-and-play wiring harness, for trouble-free installation! Thanks to Stage Series TIR optic technology, this kit provides a huge amount of extra reverse light. The included switch allows you to toggle it on any time, or activate it automatically with your reverse lights, for a truly integrated solution.
NOW AVAILABLE: Stage Series Reverse Light Kit for 2005-2021 Toyota Tacoma!-yqqdbpd.jpg
Focused: Most LED pods on the market, even certain premium options, use outdated technology like reflectors or simple lenses that lose light internally and to glare. By comparison, our custom-engineered total internal reflection (TIR) optic collects all of the light from the LED chips, drastically reducing wasted light and improving total efficiency.
NOW AVAILABLE: Stage Series Reverse Light Kit for 2005-2021 Toyota Tacoma!-kxxibqn.jpg
While other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the Stage Series LED pods serves as both the optic and main lens for greater efficiency and light output (patent pending). Thanks to this innovative feature, when coupled with high-intensity LED chips, the total intensity of the Stage Series Pod is much greater than other LED pods using basic optics or reflectors with a standard outer lens.
NOW AVAILABLE: Stage Series Reverse Light Kit for 2005-2021 Toyota Tacoma!-shnwny7.jpg
Plug and Play. Thanks to custom-molded OEM connectors, this kit is completely plug-and-play. The included adapter harness plugs right into your factory tail lights for easy installation and operation. No cutting, drilling, or additional wiring needed! The kit operates as an additional red accent light, with your tail lights, and then automatically switches to a high-power backup light when your vehicle is in reverse. The included toggle switch allows you to override the vehicle signals and turn on the main beam anytime.
Each kit will include:
  • Two (2) SSC1 or SSC2 Standard LED Pods
  • One (1) Universal Reverse Light Wiring Harness
  • One (1) Adapter Harness for 2005-2015 or 2016-2021 Toyota Tacoma
  • Two (2) Mounting brackets
  • Ten (10) Zip Ties
  • Two (2) T-Taps
  • Mounting hardware
Functional Patterns. All Stage Series beam patterns were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern.
  • Flood pattern was designed to provide uniform, even illumination with a full 50x50 degree spread of light on the SSC1 LED pod, and a 60x60 degree spread on the SSC2 LED pod. Unlike generic "flood" lights that are simply a heavily diffused spotlight, our flood pattern uses pillow optics on the outer lens surface, to provide a true optically designed spread, for even illumination throughout.
NOW AVAILABLE: Stage Series Reverse Light Kit for 2005-2021 Toyota Tacoma!-shtcq52.jpg
Backlight Functionality. The Stage Series LED pods included with this kit feature a distinctive backlight in a vibrant red color which functions as an additional accent light while driving! The backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.
Sport or Pro. Stage Series LED pods are available at two different power levels. Both options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. However, the Pro option is double the amount of total power. Click the Specifications tab to see more information!
NOW AVAILABLE: Stage Series Reverse Light Kit for 2005-2021 Toyota Tacoma!-zdmw2zz.jpg
Proven Reliability: Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
If you have any questions, please don't hesitate to post, PM, or email contact@diodedynamics.com.
PM us for the free-shipping code (U.S. forum members only)
John C.
Diode Dynamics
