🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics
Old Jun 13, 2019 | 12:28 PM
Diode Dynamics's Avatar
FormerVendor
Stealth LED Light Bar Kit for the 2016-2019 Toyota Tacoma | Diode Dynamics
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-0tnxu9r.jpg
Diode Dynamics is excited to announce our Stealth LED Light Bar Kit for the 2016-2019 Toyota Tacoma! Computer-designed specifically for the Tacoma, this LED light bar kit secures a 30” Stage Series LED Light Bar using factory mounting points. There is NO cutting or drilling needed!
The included steel powdercoated brackets allow you to easily mount the 30" Stage Series LED Light Bar in the factory lower grille opening. Again, these brackets use OEM mounting points, so you won’t have to modify your Tacoma! This Stealth LED Light Bar Kit retains the factory lower grille for a clean, OEM-like appearance. Additionally, if preferred, the lower grille can be modified to make the light bar more visible.
Features:
  • Direct fitment on 2016-2019 Toyota Tacoma.
  • Allows you to mount one 30" light bar in the lower grille opening.
  • CAD-designed for perfect fitment and OEM-like appearance.
  • Utilizes existing mounting points for easy installation - no cutting or drilling required.
  • Highly durable powdercoated steel construction.
  • Plug-and-play wiring harness included to power light bars.
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-btutij8.jpg
Diode Dynamics Stage Series Light Bars have been designed using optical simulation modeling, for maximum functionality. Their custom-engineered TIR optics provide FAR more usable light output than much larger, heavier generic LED light bars. Depending on your auxiliary lighting needs, you can order our Stealth LED Light Bar Kit with a white or amber light bar, with the following optic options:
  • Driving: The Driving pattern was designed to supplement your high beams. Rather than a simple "spot" pattern, the Stage Series Driving pattern has a rectangular 20Wx8H degree pattern that is far more useful for directing light downrange at high speeds.
  • Flood: The Flood pattern was designed to provide uniform, even illumination and a full 80Wx50H degree spread of light. Unlike generic "flood" light optics that are simply a heavily diffused spot, our flood optic is a true optically designed spread, resulting in the biggest spread in the industry! It is perfect for lighting up anything at low speeds, a backup or reverse light, or to light up a worksite.
  • Combo: The Combo pattern combines both the Driving and Flood optics. It shines light downrange in a focused, rectangular 20Wx8H degree pattern while also illuminating area around it in a full 80Wx50H degree spread. The Stage Series 30" Combo Light Bar features three driving lenses in the middle with two flood lenses on the outer edges.
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-crg2nve.jpg
Each Stealth LED Light Bar Kit features everything you need to install it on your 2016-2019 Toyota Tacoma, including:
  • Two (2) Application-Specific Heavy-Duty Steel Brackets for Installation on 2016-2019 Toyota Tacoma
  • One (1) SS30 Stage Series 30" Light Bar
  • One (1) Heavy Duty Single-Output Harness
  • All Necessary Hardware
  • Installation Guide
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-dv2dqnb.jpg
Installation: Installing our Stealth LED Light Bar Kit is simple and straightforward, requiring only basic hand tools. Check out our step-by-step installation guide for detailed instructions, or watch the install video below!
Fitment:
  • Fits all 2016, 2017, 2018 and 2019 Toyota Tacomas
  • Fits all trim levels including Limited, Limited RWD, SR, SR5, SR5 RWD, TRD Off Road, and TRD Pro
Diode Dynamics Stealth LED Light Bar Kit for the 2016-2019 Toyota Tacoma is proudly engineered and tested right here in the USA, and is backed by our 3-year worry-free warranty! Want to check out more LED lighting upgrades for your 2016-2019 Toyota Tacoma? Click here!
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Jake H.
Diode Dynamics
Old Jun 17, 2019 | 07:41 AM
FormerVendor
Check out our 2019 SEMA build Tacoma rocking the new Stealth Light Bar Kit!
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-ekmz1z5.jpg
Jake H.
Diode Dynamics
Old Jun 18, 2019 | 06:35 AM
FormerVendor
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-ga7lzqz.jpg
More output shots coming soon!!
Jake H.
Diode Dynamics
Old Jun 20, 2019 | 08:09 AM
FormerVendor
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-anuiwnl.jpg
Check out that fitment! You can also remove the secondary lower grille if you want maximum light output!
Jake H.
Diode Dynamics
Old Jul 10, 2019 | 11:42 AM
FormerVendor
Don't forget to shoot us a PM for free USPS shipping on any U.S order!
Jake H.
Diode Dynamics
Old Jul 26, 2019 | 08:51 AM
FormerVendor
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-ykonakq.jpg
Check out this awesome shot of our Stealth LED Light Bar Kit from @cbad_trd!
Thinking about picking up some LED lighting upgrades for your Tacoma? Shoot us a PM for free USPS shipping on any U.S order!
Jake H.
Diode Dynamics
Old Aug 29, 2019 | 06:54 AM
FormerVendor
Bolt-on auxiliary lighting doesn't get much better! Check out this awesome shot of our Stealth LED Light Bar Kit for the 2015-2019 Toyota Tacoma!
Jake H.
Diode Dynamics
Old Nov 1, 2019 | 07:29 AM
FormerVendor
Don't forget to shoot us a PM for FREE USPS shipping on any U.S order!
Jake H.
Diode Dynamics
Old Nov 25, 2019 | 10:02 AM
FormerVendor
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-bcbzrsx.jpg
Don't settle for generic auxiliary lighting! Diode Dynamics Stage Series LED Light Bars are fully designed and tested in St. Louis using the best components available. Additionally, we back every Stage Series Light Bar with a 8-year worry-free warranty!
Don't forget to shoot us a PM for free USPS shipping on ANY U.S order!
Jake H.
Diode Dynamics
Old Nov 27, 2019 | 10:11 AM
FormerVendor
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-ubkc7fk.jpg
Our Black Friday sale starts NOW! Today through Monday, 12/2/2019, save 20% on all LED upgrades including our Stage Series LED Light Bar Bracket Kits by entering coupon code "BLACKFRIDAY" at checkout!
Jake H.
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday 12/2/2019. Cannot be combined with other coupon codes.
Old Dec 2, 2019 | 11:30 AM
FormerVendor
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-liarosf.jpg
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 12/2/2019, you can use coupon code "BLACKFRIDAY" at checkout for 20% off your entire order of lighting upgrades, including our NEW SS3 LED Pods!!! Don't wait, this sale ends TONIGHT!
Jake H.
Diode Dynamics
Old May 27, 2021 | 09:54 AM
FormerVendor
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-tejtz7p.jpg
Our Memorial Day sale starts NOW! Today through Friday, 6/4/2021, save 15% on all LED upgrades, including our Stage Series LED Light Bar Bracket Kits by entering coupon code "USA15" at checkout!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 6/4/2021. Cannot be combined with other coupon codes.
Old Jun 30, 2021 | 08:32 AM
FormerVendor
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-ttea16e.jpg
Our July 4th Sale starts NOW! Today through Thursday, 7/8/2021, save 15% on all LED upgrades, including our newly released SSC1 LED Pod, by entering coupon code "JULY4" at checkout!
Plus, all orders over $300 will receive an exclusive Diode hat!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Thursday, 7/8/2021. Cannot be combined with other coupon codes.
Old Sep 2, 2021 | 08:47 AM
FormerVendor
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-cgzmpud.jpg
Now's the time to upgrade your ride! Our Labor Day Sale is going on NOW! Save 15% sitewide, including our Stage Series Light Bar Kits, by entering coupon code "LABOR" at checkout! And, all orders over $300 will receive a free Diode flag tee! Sale ends Friday, 9/10/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/10/2021.
*Sale excludes preorders.*
Old Sep 7, 2021 | 08:04 AM
FormerVendor
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-8uqdkrw.jpg
Just a reminder! We just released our NEW Diode Dynamics flag shirt!
All orders over $300 during our Labor Day Sale will receive one free! If you're interested in purchasing a shirt, we have them listed under the gear section on our website.
John C.
Diode Dynamics
Old Sep 10, 2021 | 06:28 AM
FormerVendor
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-ubtkiuu.jpg
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our Stage Series Light Bar Kits, with coupon code "LABOR" at checkout! Plus, get a free Diode flag tee when you spend $300! HURRY, this sale ends TONIGHT!
John C.
Diode Dynamics
Old Oct 7, 2021 | 07:22 AM
FormerVendor
What sets our Stage Series light bars apart from all others?
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-7cmqssq.jpg
They feature patent-pending Total Internal Reflection (TIR) optics that not only focus the light but reduce glare!
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-cdka9ut.jpg
John C.
Diode Dynamics
Old Nov 22, 2021 | 01:16 PM
FormerVendor
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-rvm46eq.jpg
Now's the time to upgrade your ride! Our Black Friday Sale is going on NOW! Save 15% sitewide, including our Stage Series Lightbar Kits, by entering coupon code "BF21" at checkout! And, all orders over $500 will receive a free Diode Dynamics long sleeve shirt! Sale ends Tuesday, 11/30/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday 11/30/2021.
Old Nov 30, 2021 | 07:58 AM
FormerVendor
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-minb4vt.jpg
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our Stage Series Light Bar Kits, with coupon code "BF21" at checkout! Plus, get a free Diode Stage Series long sleeve shirt when you spend $500! HURRY, this sale ends TONIGHT!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST | Tuesday, 11/30/2021.
Old Jan 21, 2022 | 12:56 PM
FormerVendor
All Stage Series LED light bars are IN-STOCK!
🚨NEW!🚨 Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics-ltjpzhf.jpg
Just a reminder, all US forum members are eligible for a free shipping code. Just PM us!
