Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
New Member. With FJ80 Driveline Clunk
Old May 12, 2004 | 05:28 PM
RandyS's Avatar
I have a 92 Landcruiser and when driving if i let up on the pedal, then step on it again i will hear and feel a clunk. It is a little worse after i have driven 2 or 3 miles. I had 4 new toyota u-joints installed thinking that would help, but it did'nt. Anyone have a idea of where to look next.
It only has 91K
Old May 13, 2004 | 09:24 AM
elnip's Avatar
It only has 91K
Maybe the rubber bushing between the crossmember and the xfer case is shot? looks ok visually but under load the case is moving to much....
My first guess
Scott
Old May 18, 2004 | 03:07 PM
Mad Chemist's Avatar
Hmmm...my first guess would have been u-joints as well. Have you crawled underneath to see if there is any play in the driveshaft?
Old Jun 1, 2007 | 12:59 PM
84RNR's Avatar
My 91 LC does the same thing. It also makes the clunk noise when you put it into gear (reverse or drive). Haven't had time to look into it yet but let me know if you figure it out. It drives great other than that.
Old Jun 19, 2007 | 07:47 PM
LandBruiser's Avatar
That is normal. Dont sweat it. The glunk is from the play in the transfer case. I have taken out my front DS and locked the center diff(TC) and driven it in 2wd,....it almost completely goes away. I dont think there is a Viscous coupling our pre '93 Cruisers.
J
Old Oct 16, 2007 | 08:21 PM
MoGas's Avatar
My clunk goes away when I grease the splines on the drive shafts. I expect that is probably your issue as you stated that it gets worse after driving a few miles.
Dave
BK2TFUTURE
Oct 11, 2015 08:42 PM
ktm192k
Oct 1, 2015 08:47 AM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
Odin
Sep 24, 2015 04:38 AM
