differential locks?
FJ80's had a center locker with optional front/rear lockers. FZJ80's had only optional F/R (switched) and a non-selectable center that was locked only when in 4lo. you can easily mod a FZJ center locker to be selectable. i have a center selectable locker on my 4runner via the push-button on the XF case shifter.
Are you referreing to the 80 or 100?
Both have the center diff lock.
However 80's were offered with front rear lockers and the 100 for some time with just a rear locker.
On the 80 the center diff was locked automatically when going into Lo, the 100's had the button. However Sleeoffroad and other offered a switch that you could install to lock the center on the 80 in Hi as well, you can then disconnect the link on the transfer case so you can have the center diff open in Lo if you want. See sleeoffroad.com
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
Odin
Sep 26, 2015 06:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
