Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
1972 Toyota Land Cruiser
Old Jun 6, 2006 | 09:57 AM
VTpaintballer's Avatar
Hi, I am looking into buying a 1972 Land Cruiser with 78,889 miles on it. Its pretty rusted (the body) and maybe the internals. It also needs new brakes, and a fuse box. It's a 3 speed and 6 cyl., the engine is in good condition. But other than that it works fine, should i buy it? ($4k)
the brakes are drum brakes
thanks
Old Jun 6, 2006 | 01:59 PM
Yoda's Avatar
Sounds spendy for a "rusty" body. Post some pix for a better idea of what it is worth.
I have a 71. I put around $500 into a full brake job some years ago (2 wheel cylinders per wheel) The good cylinders are hard to find now.
Old Jun 7, 2006 | 12:28 PM
Ok i'll get some pictures, under the door its totally rusted out, i was thinking bondo on those spots
Old Jun 19, 2006 | 02:38 PM
JGM's Avatar
JGM
If the rust is workable, its a fair price. If you will need to look into new body panels, try getting some $$ off that price.
Plenty of engine life (not even broken in at those miles).
Other stuff to check:
- steering slop - those manual systems are notorious for requiring tweaking and periodic rebuilds (center pivot).
- Birfield service - is there leaking at the knuckles?
- Rear main seal - leaking?
- Does it have a PTO? - if so, check that baby
- How does it shift? You probably don't have synchro in 1st and Rev, so go easy, but it still should shift pretty smoothly.
- Frame - make sure that the rust isn't covering up cracks or fatigues.\
Good luck!
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Aug 28, 2015 09:20 PM
nick b
Jul 11, 2015 04:38 AM
