Up to $250 Rebate on 6" Lift Kits by SuperLift for Toyota Tundra
Old Oct 24, 2023 | 05:39 AM
carid's Avatar
Premium Sponsor
Lift your truck to new heights for less with Superlift's limited time $250 rebate! Now through October 31st, 2023, you can save big when you spend $1,250 or more on Superlift lift kits and accessories. This rebate is the perfect opportunity to finally get that aggressive lift you've always wanted.
Going taller allows you to run larger, off-road tires and achieve an intimidating, lifted truck stance. Superlift engineers the highest quality lift kits right here in the USA. Built to last and backed by a satisfaction guarantee, their lifts provide the maximum clearance to conquer rocky trails while maintaining clean street drivability. But act fast, this $250 rebate offer won't last long! Level up your truck and save with Superlift.
Superlift® K962 - 6" x 4" Master Front and Rear Suspension Lift Kit
Key Facts:
With Superide Shocks
Install Time: 8-9 Hours
Install Difficulty Level: 4 of 5
Max Tire Size: 35"x12.5"
Wheels and tires recommended parameters:
35"x"12.5 Tire on 18"x9" Wheel with 5" Backspacing
35"x"12.5 Tire on 20"x9" Wheel with 5.5" Backspacing
35"x"12.5 Tire on 22"x9" Wheel with 5.5" Backspacing
Notes:
Cutting and Drilling is required
Cannot run the factory 18” wheel
Aftermarket 18” wheels require at 5” or less back spacing
Do Not combine with any other suspension lift
https://www.carid.com/superlift/6-x-...-mpn-k962.html
Installation instructions are available here:
https://images.carid.com/superlift/i...structions.pdf
