Brand-New Summit Full-Width Front HD Bumper by ARB at CARiD
Old May 12, 2021 | 04:33 AM
carid's Avatar
Premium Sponsor
If you’re looking to enhance your off-roading experience and explore all the hidden trails in your area safely, the all-new Summit Full-Width Black Powder Coat Front Winch HD Bumper with Grille Guard developed by ARB would certainly be your best choice. Crafted with all the specifications of your Toyota’s current generation 4Runner in mind, it will impress you with the exceptional level of protection and durability, while ensuring the snuggest fitment possible.
It perfectly follows the body lines of your full-size SUV and sits high beneath the bumper on the outer edges maintaining maximum ground clearance. It also incorporates the ARB’s renowned multi-fold upswept and tapered 30mm radius wing design to ensure that the approach angles remain optimal.
ARB - Summit Full-Width Black Powder Coat Front Winch HD Bumper with Grille Guard
Fits: 2014-2021 Toyota 4Runner
Notes: Includes 3501030 Winch Installation kit. Winch sold separately.
Features:
  • Durable steel construction for maximum protection
  • 30mm radius on wings and center section
  • Engineered, air bag compatible mounting system secures to the chassis via high tensile bolts
  • Split-pan design for maximum strength and airflow
  • Three-piece grill design for split pan
  • Extensive protection panels on center and each side
  • Two aerial brackets located on the top of the center tube
  • Will accommodate Warn, Magnum, Bushranger, Smittybilt low mount model electric winches up to 10,000lb
  • Provision for OE fog lights
  • Bar adds approximately seven inches to the overall length of the vehicle
  • Approximate weight of the bar, chassis mounts, and fitting kit is 192lbs
  • Metaprep primer for additional corrosion resistance
  • Finished in IntegritTM textured black powder coat
Click here for more details about the new ARB Product: https://www.carid.com/arb/news/quick...a-4runner.html
PureTacoma_Tundra
PureTacoma_Tundra
Apr 28, 2015 09:40 AM
