Toyota 9.5" Replacement/Upgrade Axle Housing & 3rd Member
Old Feb 21, 2017 | 06:30 PM
justdifferentials's Avatar
The 2009 & Older FJ Cruisers, 4-Runners, and Prado 120 utilize the 8” which dates back to 1979, and was originally used in 3000 lb mini trucks with 80 Horsepower and 27” tires. Late model modified Toyota's such as FJ Cruiser run at double the weight, triple the horsepower, and much larger tires to top it off. For this reason there have been lots of failures. Finally a robust solution! Diamond Axles is well known for heavy duty axle housings for off-road use, and we now offer a package with the best 9.5” Toyota diff offered. This combo offers significant improvements such as beefier casting, larger bearings, larger pinion diameter, larger ring gear diameter, more tooth contact, and a beefier 12 bolt diff case. This makes for an easy swap for your vehicle and will utilize your existing axle shafts, brakes, abs system etc.
Base price is for an empty axle housing. It will also require a 3rd Member, choose from the dropdown above. Also optionally you can add the chromoly rear axle shafts and/or a matching 3rd member for the front. If you have questions or want another option, please call or email.
Nitro Gear & Axle strives to provide the highest quality differential & axle components available. We take the steps necessary to ensure our parts are dependable. Our product range is continually growing to meet the needs of consumers for new ratios and applications. At Nitro we know differentials, and know what it takes to provide you with high quality components.
Click HERE for pricing, and more information.
Toyota 9.5" Replacement/Upgrade Axle Housing & 3rd Member-ix1aeszl.jpg
Toyota 9.5" Replacement/Upgrade Axle Housing & 3rd Member-bybcdaql.jpg
Fits:
  • 2007-2014 Toyota FJ Cruiser
  • 2003-2009 Toyota 4runner
  • 2010-Present Toyota 4runner
  • 2003-2008 Lexus GX470
  • 2009-Present Lexus GX460
  • 2003-2008 Toyota Land Cruiser Prado 120 Series
  • 2009-Present Toyota Land Cruiser Prado 150 Series
