Ruffstuff Axle Simple Swap Kit!
Old Jun 15, 2012 | 10:08 AM
Gravel Maker's Avatar
FormerVendor
Arrow Ruffstuff Axle Simple Swap Kit!
This is the basic kit essential for an Axle swap, more items could be added but this is the bare minimum, You will receive 1 pair of our 3/8" thick A50 Steel U-Bolt plates with 3 pin mounting options, a pair of our Spring Perches with the same pin option to match, 4 - 10" x 5/8" Fine thread Grade 8 U-Bolts with 1/4" thick cut Hardened washers and real Ubolt Hardened Tallnuts, and a pair of Shock Brackets. This will get your Axle under the rig. BTW, this is NOT a Chinese made product that just can't hang with the big kids, this IS the Big Kid.
BTW, our Ubolts are the correct size for your Axle, not 1 size fits all.......these are offered with 8 Axle diameters and 5 Leaf Spring perch widths.........UPDATE.........Now also available in 3.5" D70/Sterling diameters & D60 GM, Ford, & Dodge front swaps too! And I almost forgot, Ford fullsize 3" Leaf Spring widths also......
Old Jun 15, 2012 | 10:46 AM
RBX's Avatar
RBX
I just used this exact kit yesterday to install my Old Man Emu Leafs and shocks, very beefy and the ubolt plate won't flex when you torque the bolts down...highly recommended....thanks Dan.
Old Jun 18, 2012 | 09:53 AM
RBX's Avatar
RBX
Bump for responding to an email i sent with a question on Sunday morning...that, is service!
Old Jun 19, 2012 | 05:16 PM
FormerVendor
Thanks guys! Nothing beats a recomendation
Old Jun 19, 2012 | 05:33 PM
rattlewagon's Avatar
I like that it comes with the shock mounts..
Old Jun 22, 2012 | 04:23 AM
RBX's Avatar
RBX
Got my replacement plates on Wednesday, POR-15'd and will install this afternoon before my trip to Rausch Creek.
What are the torque specs for these beasts? The FSM recommends 75ftlbs(stock) i cranked these monsters to 90ftlbs.
Dan can you elaborate?
Old Jun 23, 2012 | 11:27 AM
FormerVendor
I think you did well.
I hate to say it but I don't thnk the factory uses the FSM. They put Ubolts on to stay on! When I do it I set the impact to tight and I stop when it gets tired...(90-100FT/lbs)
Old Jun 24, 2012 | 02:06 PM
RBX's Avatar
RBX
Thanks, I actually found those specs in a taco thread referring to that FSM
Old Jul 17, 2012 | 11:07 AM
FormerVendor
Thumbs up Ruffstuff Axle Simple Swap Kit!
We make it simple just for you.. Just the basic parts.. No over the top Fancy go fast holes or stars or skulls.
Old Aug 15, 2012 | 01:42 PM
FormerVendor
Smile Ruffstuff Axle Simple Swap Kit!
A great way to start fresh when building a new axle !!
Old Sep 7, 2012 | 10:38 AM
FormerVendor
Just the basic parts to get the job done !! No flare or glitter to run up the cost
Old Oct 3, 2012 | 07:49 AM
FormerVendor
Swap in that axle!
Old Nov 7, 2012 | 10:05 AM
FormerVendor
We made it simple for you!
Old Dec 3, 2012 | 08:50 AM
FormerVendor
Thanks for all of the orders!
Old Dec 13, 2012 | 07:26 PM
FormerVendor
Doesn't get much simpler!
Old Dec 20, 2012 | 09:36 AM
FormerVendor
The easiest way to get that axle in!
Old Jan 2, 2013 | 09:26 AM
FormerVendor
Make it simple on yourself!
Old Jan 11, 2013 | 08:24 AM
FormerVendor
The best way to swap in any axle!
Old Jan 21, 2013 | 08:58 AM
FormerVendor
Running IFS? make it easy to swap in the new axle with our simple swap kit!
Old Feb 13, 2013 | 09:57 AM
FormerVendor
Doesn't get much easier!
